[SOLVED] Adding nodes as layers / references through API
Hi all,
I'm having issues loading nodes as references or layers into the scene through the C++ API. We are currently loading nodes into the World (in editor- and in release mode) like this:
auto node = Unigine::World::get()->loadNode(path);
Unigine::Editor::get()->addNode(node);
I'd like to replace this to use either Node References or Node Layers instead, but I can't get it to work properly.
What I tried was:
auto node = Unigine::NodeReference::create(path);
Unigine::Editor::get()->addNode(node->getNode());
This crashes somewhere in the Unigine internals on world update, it looks like the node pointer gets invalidated after "node" goes out of scope. Am I missing something that I need to do to have the Editor take over ownership of the reference? I can't find any method to add the node to the current world, even though I'd assume this needs to be done somehow...
Also, is it possible to load nodes as References / Layers without adding them to the Editor? In the first snippet, I can simply omit the call to Editor::get()->addNode(), then the Node is present in the World but not visible in the editor.
Try use release() before add in Editor.
auto node = Unigine::NodeReference::create("NodeDummy.node");
if (node)
	node->release();
yes, you can use nodereference without Editor. But you have to destroy the nodes yourself.
  • silent changed the title to [SOLVED] Adding nodes as layers / references through API
