[SOLVED] WidgetCanvas's polygons disappear when they don't have to
Hi! I use WidgetCanvas to create outlines like in tables. I also use WidgetScrollBox (to scroll table). So, the problem is: when one point of a polygon leaves visible area in scrollbox the whole polygon disappears. Is there any workaround? Or maybe I use canvas in a wrong way.. I've attached example code (when scrolling down very slowly you can notice that upper polygon disappears though it still has to be in its place).
Also I found out that Gui::CHANGED callback for scrollbox works only when mouse is pressed onto scrolls. How can I detect using only mouse wheel?
source.7z
I'm trying to create a table class like in MS Excel (not through .ui but through C++ API). So the main idea is to create a container for widgets and draw borders around it. And I also need to scroll through this table (vertical and horizontal scrolls, example below).
I need it as soon as possible...
Edited by naumova.natalya
We've taken another look at this.
1. You can fix disappearing canvas polygon by deleting or commenting the following string:
canvas->setPosition(10, 10);
2. Detecting mouse wheel can be done manually, by imitating a callback, for instance:
if (App::get()->getMouseAxis(App::AXIS_Y) != 0) {
   // Do something...
Then check if scrollbar position was changed in the same AppWorldLogic::update():
	if (scrollbox->getHScrollValue() != old_hscroll || scrollbox->getVScrollValue() != old_vscroll)
		// Do something...
	old_hscroll = scrollbox->getHScrollValue();
	old_vscroll = scrollbox->getVScrollValue();
Please, let us know if this works for you.
  • morbid changed the title to [SOLVED] WidgetCanvas's polygons disappear when they don't have to
