javier.serrano Posted April 2, 2019 Share Posted April 2, 2019 (edited) Hi, we have placed 2D Widgets over some 3D objects to display their info. We have implemented camera controls (zoom in/out, panning and orbit) and we realized that Widgets do overlap in some camera positions. Problem is that Widget painting is not done correctly in screen-space Z order. We tried using Widget::setOrder() and Widget::raise() but we could not come to a solution. How can we sort Widgets to make them paint correctly (closer to camera in front and furthest at back)? Regards, Javier Edited April 2, 2019 by javier.serrano Link to comment
alexander Posted April 4, 2019 Share Posted April 4, 2019 Hi Javier, Widget::setOrder() works only for ALIGN_OVERLAP and non-ALIGN_FIXED widgets when you use Widget::addChild() function. Look at the example: Unigine::Vector<Unigine::WidgetSpritePtr> sprites; int AppWorldLogic::init() { // create 3 squares with different colors for (int i = 0; i < 3; i++) { WidgetSpritePtr &sprite = sprites.append(); sprite = WidgetSprite::create(Gui::get(), "white.dds"); sprite->setPosition(i * 40 + 50, i * 40 + 50); sprite->setWidth(100); sprite->setHeight(100); Gui::get()->addChild(sprite->getWidget(), Gui::ALIGN_OVERLAP); } sprites[0]->setColor(vec4(1, 0.3f, 0.3f, 1)); sprites[1]->setColor(vec4(0.3f, 1, 0.3f, 1)); sprites[2]->setColor(vec4(0.3f, 0.3f, 1, 1)); return 1; } int AppWorldLogic::update() { // press space key to random reorder squares if (App::get()->clearKeyState(' ')) { for (int i = 0; i < 3; i++) { sprites[i]->setOrder(Game::get()->getRandomInt(0, 10)); Gui::get()->removeChild(sprites[i]->getWidget()); Gui::get()->addChild(sprites[i]->getWidget()); Log::message("%d ", sprites[i]->getOrder()); } Log::message("\n"); } return 1; } Best regards, Alexander Link to comment
javier.serrano Posted April 4, 2019 Author Share Posted April 4, 2019 Hi Alexander, this fits perfectly our needs. Thanks a lot, Javier Link to comment
