[SOLVED] In AppWall GUI focus works incorrect.
I'm using AppWall and MOUSE_SOFT. I have two gui pointers gui_prim and gui_sec. I trying to create a dialog in runtime. For simplifying problem, i use WidgetWindow in example.
I have three different types of behavior.
1 - I create window in primary gui and then attach window to it:
	WidgetWindowPtr wnd = WidgetWindow::create(gui_prim, "test window");
	gui_prim->addChild(wnd->getWidget(), Gui::ALIGN_OVERLAP | Gui::ALIGN_CENTER);
	wnd->release();
Everything works correct. Widget is created in the center of left screen, and overlaps any element.
2 - Create in prim or sec (same bahavior), attach to sec
Window appears in the center of a right screen, but if i click at any widget, i can interact with (edittext, scrollbox, etc), window moves under it.
3 - Create in sec, add in prim
If i move window over edittext, editline etc - ok, but if i move window over scrollbox and click on it (on window), it stopes to interact with mouse, but stil renders over scrollbox.
wnd->setPermanentFocus(); doesn't help
Thank you.
Hello, I made a simple example with this error.
When I create wdt_edittext in gui_sec - everything works correct, but if i create it in gui_prim - wdt_edittext overlaps dialog.
I have to create it in gui_prim, because in my actual programm i use UI-file.
Command arguments are -data_path ../ -engine_config "../data/Test_gui/unigine.cfg" -console_command "" -width 2 -height 1 -extern_plugin "AppWall" -extern_define MOUSE_SOFT
PS: i have modified version of AppWall.cpp see
AppSystemLogic.cpp AppSystemLogic.h
Edited by muslaev.ilya
Hi, thanks for the sample.
All issues are caused by unusual usage of widgets and gui. If you'll create a widget in the same gui it'll work as expected.
This code works fine:
wdt_edittext = WidgetEditText::create(gui_sec);
wdt_edittext->setHeight(400);
wdt_edittext->setWidth(500);
gui_sec->addChild(wdt_edittext->getWidget(), Gui::ALIGN_CENTER | Gui::ALIGN_OVERLAP);
This one isn't:
wdt_edittext = WidgetEditText::create(gui_prim);
Could this be a typo or you're doing this on purpose?
Thanks.
I'm doing this on purpose, because in my program i using UI file. So i create UserInterfacePtr in gui_prim, but attach widgets in different monitors (gui).
ui_file = UserInterface::create(gui_prim, "Interface.ui");
wdt_hbox_prim = WidgetHBox::cast(ui_file->getWidget(ui_file->findWidget("hbox_prim")));
gui_prim->addChild(wdt_hbox_prim->getWidget(), Gui::ALIGN_OVERLAP);
wdt_vbox_sec = WidgetVBox::cast(ui_file->getWidget(ui_file->findWidget("vbox_sec")));
gui_sec->addChild(wdt_vbox_sec->getWidget());
Is the only way is to create a different ui file for each monitor?
  • morbid changed the title to [SOLVED] In AppWall GUI focus works incorrect.
