create Entity.
I used Ig_templete defualt.
be_200's Entity ID is 200 in ig_config.xml.
so I created Entity that set id to 200 using Hemu.
But nothing happened.
in update() of SystemLogic, I used this simple code
int count = cigi->getNumHostPackets();
    for (int i = 0; i < count; i++)
        IG::CIGI::ICigiHostPacket* request = cigi->getHostPacket(i);
        if (request->getType() == IG::CIGI::CIGI_OPCODE_ENTITY_CONTROL)
            IG::CIGI::ICigiEntityControl* EC = dynamic_cast<IG::CIGI::ICigiEntityControl*>(request);
            IG::IEntity* en = ig_manager->getEntity(EC->getEntityID());
            en->setRotationEuler(EC->getRotation());
            en->setGeoPosition(EC->getPosition());
How create Object Node that related to Entity?
14 hours ago, cash-metall said:
create a terrain with a geodetic pivot
Does this mean that the world with terrain made from Geo-referenced data should be designated in the ig_config?
if enable Geodetic Pivot, background screen gets a little strange.
When making a Terrain, are the common values of the automatically generated GeodeticPivot normal?
(if coordinates parameter set to East-North-Up Mode, Common values are automaticly changed.)
Or should I set the position and rotation to initialization(0,0,0)?
Edited by dongju.jeong
EntityControl packet works automaticly, additional processing is not required.
Does this mean I don't need to use the SetRotationEuler,SetGeoPosition function of Intity?
Is it handled automatically from the inside?
Quote
yes. EntityControl is already supported.
Quote
yes. you need specificate database name
Callbacks for receiving packets are needed only for additional processing, which is not provided for by the IG, for example, creating an UI or other unusual behavior.
  • Like 2
thank you cash.
I've tried the things you've offered me.
image.png.238641487912f7d1baba640b86a962c2.pngimage.png.55f704d85afe28a3e4a04792f3a42553.pngimage.png.bb64c9cd1cc2fc4f3b5277038db197b8.png
Even if I set the latitude and longitude of the plane to camera's position, I can't see plane.
Am I using Hemu incorrectly?
If I change the time, only the background changes to the Star background.
By any chance, should be_200 nodereference be placed in world in advance by editor?
I want to see the airplane being controlled by Hemu after the airplane is made in front of a fixed camera.
Quote
By any chance, should be_200 nodereference be placed in world in advance?
No, it is not necessary to place nodes in advance. They should be automatically created.
I can't understand why you can't create an entity. Do you control the camera manually in your application? Do you use a syncker plugin? Any errors/warnings in log? Please, attach log.html file
I attached IG to VR sample project. (Ig folder, xml file and dll(IG,CIGI,HLA))
I'm not using Syncker, and I'm connect Vive to control the camera.
There seems to be no error in the log.
log.html
Hi, cash-metall
I have another question.
Do packets related to CigiIGPacket works automaticly in Basically?
should I use "createIGPacket,addIGPacket" function if special operation is required?
Yes, you can.
Most packages are processed automatically, but you can also use "createIGPacket, addIGPacket" methods to implement your host logic, or to implement unsupported packages.
