qwert_e Posted February 13, 2019 Share Posted February 13, 2019 Hello. Is there an opportunity to customize fbx import in Editor? I`m trying to process model materials that have multi texture layers that have references to files. Editor (by default) make new empty materials for those surfaces. When my custom import "class FbxImporter : public Unigine::Importer" start processing fbx file, it runs FbxImporter::onInit function, and then FbxImporter::onImport function not called (why???). after that it invokes FbxImporter::onImportMesh and FbxImporter::onImportNode from internal (Unigine_double_x64.dll), and bool onImportMaterial never called. here is debug func calls: FbxImporter::FbxImporter FbxImporter::onInit Model up(Y) front(Z) name(fire_station). Required up(None) front(None). FbxImporter::process_node, new node(fire_station) FbxImporter::process_node, new node(fire_station%lod0) FbxImporter::process_node, new node(fire_station%lod0) FbxImporter::process_mesh FbxImporter::onImportMesh, mesh name(fire_station%lod0) FbxImporter::create_mesh `anonymous-namespace'::create_geometry `anonymous-namespace'::create_surfaces FbxImporter::onImportNode, node name(fire_station) FbxImporter::~FbxImporter I need to process materials - choose existing material from library, inherit it to needed place and assign to node when import Link to comment
silent Posted February 13, 2019 Share Posted February 13, 2019 qwert_e onImport() is not called inside Editor, use it only for realtime FBX import.onImportMaterial should be calling if FBX contains some materials (maybe it will be required to manually enable 'Override materials'). FbxImporter::import_materials should be right place to look at. A full source code of your modifications would be great to look at, right now it's not completely clear what is going on. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
qwert_e Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) In FbxImporter::import_materials it assigns String ImportMaterial.name and void* ImportMaterial.data as fbx::FbxSurfaceMaterial *. And i stucked, because i don`t know where it parse ImportMaterial.data and creates new materials (that are added to data/materials folder). I need to get data from fbx multimap, and assign surface material to one i have in my material library Edited February 13, 2019 by qwert_e Link to comment
danvern Posted February 14, 2019 Share Posted February 14, 2019 Parsing ImportMaterial::data happens in function create_material, assigning material for surface happens in method FbxImporter::process_mesh Link to comment
qwert_e Posted February 14, 2019 Author Share Posted February 14, 2019 On 2/13/2019 at 1:01 PM, silent said: (maybe it will be required to manually enable 'Override materials'). That helped. It named "Overwrite Assets" in Assets mode editor import gui window. In Editor mode i can`t assign processor for material, so i swapped MaterialPtr &material in bool FbxImporter::onImportMaterial(ImportProcessor *processor, MaterialPtr &material, ImportMaterial *import_material) to material that i need according to data in ImportMaterial *import_material. Thanks! Link to comment
