Cigi & Component behavior
I observe a different behavior of a IG Component depending on whether the component is solo or not in an entity. Let me explain:
Here is an excerpt from my ig_config.xml:
		<entity id="160" name="h160">
			<path>entities/h160/h160.node</path>
			<component id="34" name="rotor">
				<property>rotor</property>
				<parameter name="data1">rpm</parameter>
			</component>
			<component id="35" name="rotorwash">
				<property>rotorwash</property>
				<parameter name="data1">wind_percent</parameter>
				<parameter name="data2">sand_percent</parameter>
			</component>
		</entity>
		<entity id="260" name="rotorwash">
			<path>entities/rotorwash/rotorwash.node</path>
			</component>
		</entity>
As you can see, the "rotorwash" component is solo for the entity #260 but not in the #160. What I observe at runtime (with Log::message) is that I can drive the wind_percent & sand_percent of the rotorwash through Cigi component control of entity #260, but not of #160.
(attached rotorwash component source, if it matters).
What am I doing wrong?
source.zip
Hi Amerio,
You need to specify the path to the node where the property is located.
 <node>path/to/node</node>
</component>
Note: NodeReference not supported in <node> tag.
I think this is it. But the property is indeed in a NodeReference. As you may have guessed, I made a NodeReference for the rotorwash effect that is embedded in many different helicopters, so they all share the same setup. So this isn't possible? Or should I do this differently?
  • 2 weeks later...
