Animation for specific bones
Hello
I have skeleton set by Inverse Kinematics
and animation where only some bones(not affected by IK) need to be animated,
how to apply animation only to list of specific bones?
reading  https://developer.unigine.com/en/docs/2.7.2/api/library/objects/class.objectmeshskinned
tried enable/disable some - with no difference by setLayerBoneTransformEnabled
and setLayerEnabled must be disabled or enabled in this case?
//setup animation layer
for (int i = 0; i < smesh.getNumBones(); i++)
   smesh.setLayerBoneTransformEnabled(layer, i, i >= 31 && i <= 47 ? 1 : 0);
smesh.setLayer(layer, 1, 1);
int animIndex = smesh.addAnimation(animPathNameExt);
smesh.setAnimation(layer, animIndex);
// in loop
// IK setup bones
// play animation
smesh.setFrame(layer, (float)Time * (Frames - 1));
Hi lightmap,
At first glance it looks like a bug in the engine's method setLayerBoneTransformEnabled(). Thank you for this.
Workaround:
1. Save all IK bone transforms
2. Call setFrame()
3. Restore all IK bone transforms
Best regards,
Alexander
let me know if it is bug, maybe it is not, probably I'm using it wrong
setLayerBoneTransformEnabled() meant to be used only with setLayerBoneTransform? or it also must affect animation in that layer?
does that mean Unigine can't apply animation from *.anim only for list of some bones ?
(animation must apply from some hierarchy branch till end leafs, not random bones)
or there options?
in case where I need to combine two animations, for left and right parts of model (single skinned mesh)
I have two animations - Left.anim and Right.anim, separately each must have weight 1.0f
for Left.anim only left side animated, right side 0 and same as bind pose
if both animation triggered - each layer blended as result in mid state <- I need a final state for both left and right
so I need to exclude some bones from blending
Hi lightmap,
Look at our animation samples (SDK Browser -> Samples -> UnigineScript -> Animation). They are difficult to understand, but this is what you need. You need to use inverseLayer() and mulLayer() functions to mix your animations:
// ObjectMeshSkinnedPtr mesh;
void init()
	mesh->setNumLayers(3); // 2 animations + 1 temporary
	mesh->setAnimation(0, "Left.anim");
	mesh->setAnimation(1, "Right.anim");
	// create a temporary reference layer 2 to calculate the mixed animation
	mesh->setFrame(1, 0.0f);
	mesh->inverseLayer(2, 1);
void update()
	// play animation
	float time = engine.game.getTime();
	mesh->setFrame(0, time);
	mesh->setFrame(1, time);
	// combine two animations:
	// 1) find local transformations of all bones relative to the frame 0 of the "Right.anim" animation
	//    and put result to the layer 1
	mesh->mulLayer(1,2,1);
	// 2) add local transformations of "Right.anim" animation bones to the "Left.anim" and put result to
	//    the layer 0
	mesh->mulLayer(0,0,1);
Best regards,
Alexander
