dongju.jeong Posted January 28, 2019 Share Posted January 28, 2019 What is the purpose and usage of the Triggers class? workflow is After creating a primitive node(box,sphere..) in the world, register that on Triggers class, and use it as a Trigger? Link to comment
fox Posted January 28, 2019 Share Posted January 28, 2019 Hi Dongju, Triggers is a framework class used to mark room obstacles for the VR Player (e.g. room walls, objects, etc.) and give a warning if there is an obstacle on the way (as the player gets closer to an obstacle, controllers' vibration becomes more intense). You can simply create primitives for walls and objects in your room and add them as children to the node dummy named Obstacles, which is a child of the VR dummy node (see the hierarchy in the Editor). You don't need to register anything, as it is done automatically (all children of the Obstacles node are switched to invisible mode and used only to inform the player and prevent collisions with objects in the real room). Please note, however, that the primitives used to mark obstacles must have their first surface (the one with 0-index) named as "box", "sphere", "capsule" or "cylinder" in order to be properly converted into corresponding trigger volumes. Obstacles are not available for VRPlayerPC. Hope this helps! Thank you! 1 Link to comment
dongju.jeong Posted January 29, 2019 Author Share Posted January 29, 2019 14 hours ago, fox said: that the primitives used to mark obstacles must be named as "box", "sphere", "capsule" or "cylinder" in order to be properly converted into corresponding trigger volumes. Do I need to set both the node name and the surface of the node to box, sphere? (or capsule etc) Link to comment
fox Posted January 29, 2019 Share Posted January 29, 2019 The name of object's surface must be as described above (only the first surface, i.e. having the 0-index, is considered). Sorry, updated the previous message. Thank you! Link to comment
