Detail mask UV transform does not work
When adjusting parametrs on Detail mask UV Transform, it doesnt do anything
Link to post
Hi, demostenes.
Yes, it is normal if the Detail Mask state in the UV mapping section is set to Base which is the default value.
Check this state please, since to have the Detail mask UV Transform parameter taken into account, it should be switched to the Uv0 or Uv1 option (see more).
Yeah, it seems a bit inobvious, I think it's better to hide the param when an inappropriate state is selected.
Sorry for the little inconveniece.
Thank you!
Link to post
Agree :) Thanks a lot.
Edit: It works as described, so please close.
Edited by demostenes
Link to post
