Handing input controls while Editor running application logic
While Editor is running and application logic is on, I would like to handle input from keyboard.
Currently I am using a "Usage Example\Basic Object Movements" example from documentation
int init()
  engine.visualizer.setEnabled(1);
  Player player = new PlayerSpectator();
  player.setPosition(Vec3(0.0f,-3.401f,1.5f));
  player.setDirection(Vec3(0.0f,1.0f,-0.4f));
  engine.game.setPlayer(player);
  int index = engine.editor.findNode("Player");
  if (index != -1)
    sphere = engine.editor.getNode(index);
  engine.controls.setStateKey(CONTROLS_STATE_AUX_0, 'p');
// start of the main loop
int update()
  if (sphere != NULL)
    float ifps = engine.game.getIFps();
    float angle = ifps * 90.0f;
    // get the current world transform matrix of the mesh
    Mat4 worldTransform = sphere.getWorldTransform();
    // get the direction vector
    Vec3 direction = Vec3(worldTransform.col1);
    engine.visualizer.renderDirection(sphere.getWorldPosition(), vec3(direction), vec4(1.0f, 0.0f, 0.0f, 1.0f), 0.1f, 0);
    if (engine.controls.getState(CONTROLS_STATE_AUX_0))
      Vec3 delta_movement = direction * movement_speed * ifps;
      sphere.setWorldPosition(sphere.getWorldPosition() + delta_movement);
    mat4 transform = sphere.getTransform() * rotateZ(angle);
    sphere.setTransform(transform);
but input is ignored when I am running a project in Editor.
If I run the project from the DSK browser it works as expected.
How can I handle the same input while the editor is executing application logic. Otherwise I have to keep running the project which is not the best experience while developing?
Thanks,
Andrew
Hi Andrew,
that should work. Have you tried switching to the Engine Viewport and clicking inside the viewport? This will shift the focus from the editor and your input should work as expected.
Thank you.
Hi Morbid,
Thank you, I'll try that when I get home.
I think I would have tried that in the first place, but there is a small chance that I didn't :)
Cheers
