dongju.jeong Posted November 14, 2018 Share Posted November 14, 2018 When I move the HMD, it moves well on the screen, but the position and angle value of the player node do not change. How can I get the actual angle and position when I move the HMD? Link to comment
alexander Posted November 14, 2018 Share Posted November 14, 2018 Hi, dongju.jeong! If you use VR Template, you can get the actual transform of the HMD using the VRPlayer::getHead() function. If you don't use it, you can get a local transform with getDevicePose() in AppVive/AppOculus plugins. Best regards, Alexander Link to comment
dongju.jeong Posted November 15, 2018 Author Share Posted November 15, 2018 AppViveProxy class is vive Plugin?? Is not it something I have to include (like using leapmotion)? Link to comment
fox Posted November 15, 2018 Share Posted November 15, 2018 AppViveProxy class is a part of the VR Template. Both plugins implementing HMD support (AppOculus and AppVive) have UnigineScript interface. So, in order to use them in our C++ project we need a proxy class (sort of API "translator") for each of them, wrapping UnigineScript methods in C++. So, if you use the VR Template it is already there. Thank you! Link to comment
