LeapMotion Camera Rotation Issue
Now I am using leap motion plugin.
The problem I met is that
In the demo project, the function
    Vec3 leap_pos_to_world_pos(const Unigine::Math::vec3 &pos)
        Vec3 wpos(pos);
        std::swap(wpos.y, wpos.z);
        wpos.y = -wpos.y;
        wpos.x -= lm->getBaseline() / 2;
        auto iwt = main_camera->getIWorldTransform();
        iwt.setRotateZ(180);
        return iwt * Vec3(wpos);
is Ok for the demo, but when I rotate the main_camera, this position transformation function doesn't support, it only support the camera whose rotaion is (180,0,0).
and I am confused by the following code:
could you explain the above codes for me? Thanks.
And if I want the main_camera to be the VR camera, which is not a static one and can rotate all the time, how should I  make the transformation for the camera transform?
 Thanks.
Hi! This demo isn't generic. If you want to "attach" hands to camera try use this code. This can help for your case.
At first, hands coordinate system is world, then you need move them to camera and correct rotation.
It works for "main_camera" random transformations.
	Vec3 wpos(pos);
	wpos.y = -wpos.y;
	return main_camera->getWorldTransform() * rotate(Vec3::RIGHT, 180.0) * rotate(Vec3::UP, 180.0) * Vec3(wpos);
