Replace system menu
How can I change the system menu, which is called by pressing ESC?
I would like to show the user my menu.
In order to check the button pressing I use this function:
bool Utils::checkKeyPressed(int _key)
    if (Console::get()->getActivity())
        return false;
    if (App::get()->getKeyState(_key))
        App::get()->clearKeyState(_key);
        return true;
    return false;
This feature correctly displays the pressing of many keys but does not operate when pressing ESC
void MainGui::update()
    if (!gui)
        init();
    if(Utils::checkKeyPressed(App::KEY_ESC))
        static int i = 0;
        Log::message("Esc pressed %d\n", i++);
What am I doing wrong? How to catch the ESC  key pressing and cancel the display of the standard system menu?
There is a section in core system script that handles the ESC key pressing (data\core\scripts\system\system.h). You can pass MENU_USER define on engine start-up to disable menu by ESC.
Please, refer also to the following forum threads:
I pass -extern_define MENU_USER as argument to engine and this helps to handle ESC button.
But how i can show/hide this system menu from my cpp code?
Can I modify system menu? I try modify <sdk\data\core\scripts\system\system.h>, but it has no effect.
Edited by neborak_a
