Video Grabber Tool - Visualize Frame Size
When you pull up the video grabber tool to save out animations or stills it would be great to be able to visualize what is going to be saved out "aspect ratio" wise.
Take the below image for example.  The viewport I'm setting up a camera in, does not reflect the 4K 3840x2160 aspect ratio the final image will be saved in.
This is not an issue for real time sim's I'm sure.  But for video saves and stills it would be nice to be able to setup a camera with the proper preview...
Another option, very simple to maybe setup...is add a dropdown under the SCENE section that would force the aspect ratio of that viewport to a preset value (the user could setup different ones)  ie...16x9, 4x3, 16x21 etc...
  • 2 years later...
Is this feature already implemented?
thanks!
You can set-up rendering Virtual Resolution in Windows -> Settings -> Render ->Screen to get the expected behavior (black bars appears and so on):
But there is no UI that will allow you to choose from the pre-defined set of resolutions / aspects.
Thank you!
It works just as I needed!
Thanks for the fast response.
  • Thanks 1
