inoperative kinect plugin
Hi
I created a project using the SDK browser, added a kinect addon.
Once I get started, I get an error see the attached log file
. Kinect hardware is OK, installed kinect runtime,SDK and tools are versions 1.8
can't load "Kinect_x64d.dll"
log.html
Link to post
Hello @aargh,
Release version of kinect addon should be running correctly. Debug version of Kinect addon requires msvcp120d.dll & msvcr120d.dll, this is debug version of libraries provided with Microsoft VC++ 2013
Link to post
Hi
Here is log from release version.  can't load "Kinect_x64.dll"
which version of kinect SDK are you using for compilation? 1.8 or 2.0 ?
log.html
Link to post
Hi @aargh,
Kinect plugin developed to work with Kinect for Windows v2 sensor, which requires Kinect SDK 2.0 (kinect20.dll library)
Link to post
Hi
Yes, that's the cause. I have Kinect v1. So I have to write the plugin myself ...
                                                         Thanks for the information
P.S.  Possible idea to extend the error message.
Error 126 is not quite obvious, it would be better to describe the error.
Link to post
Thanks aargh,
unfortunately, these dll errors (code 126, 127 etc) are never obvious. It's a standard error code and we can't extend message just because such errors have no unique reason. Usually, you have to check the dependencies for .dlls to solve this.
Link to post
