javier.serrano Posted July 5, 2018 Share Posted July 5, 2018 Hi, we are developing an application with Qt following the same structure as in QML sample. Cause of other external dependecies we need to launch our application in <project>/ instead of default Unigine directory <project>/bin/. We have ensured that all datapath are properly set relative to this new working directory. We also build .ung packages for protecting our content. When running the application in our dev folder repository everything works fine. In our test folder, when we replace content folders by .ung packages (for testing our release to customer), materials and properties loading fails and seems that are loaded twice. If we replace .ung packages by folders or we launch app from <project>/ everything works fine. ¿Any ideas of why is this happening? Regards, Javier Link to comment
silent Posted July 5, 2018 Share Posted July 5, 2018 Hi Javier, How do you build .ung packages? Do you have a small test project that we can run on our side and see what is going on here? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
