Custom messages between master and slaves with syncker
I'm trying to exchange custom messages between the master and slaves. I've tried using the setTCPUserReceiveCallback on the slave, and sendTcpUser on the master, but when receiving a message, the slaves just freeze. Here is the code I used (I couldn't find an example in the samples/demo, so I just had to guess how to use it):
class TcpUserReceive : public Unigine::CallbackBase1<const BlobPtr&> //< Is it the way to do it?
	void run(const BlobPtr& blob)
		String str = blob.get()->readString();
		Log::warning("Received: %s\n", str.get());
} tcpUserReceive;
int AppWorldLogic::init() {
	int syncker_index = Engine::get()->findPlugin("Syncker");
	if (syncker_index != -1)
		Syncker::ManagerInterface* syncker_manager = (Syncker::ManagerInterface*)Engine::get()->getPluginData(syncker_index);
		if (!syncker_manager->isMasterInitialized()) //< do it only on slaves
			syncker_manager->getSlave()->setTCPUserReceiveCallback(&tcpUserReceive);
int AppWorldLogic::update() {
	if (App::get()->clearKeyState('x') && !Console::get()->getActivity())
			if (syncker_manager->isMasterInitialized())
				BlobPtr blob = Unigine::Blob::create(100); //< what if I pass 0? Is the buffer resized auto?
				blob->writeString("custom message");
				syncker_manager->getMaster()->sendTCPUser(~0, blob);
Thanks for your help.
Hi again,
I think you need to reset the current position of your Blob to the beginning before call sendTCPUser(). In future releases i will do it for you automatically.
There is a simple way to do it. There is no need to create a new class.
Yes. It is the same as:
BlobPtr blob = Unigine::Blob::create();
blob->resize(100);
So, try this code:
void AppWorldLogic::tcp_user_receive(BlobPtr &blob) // !
	String str = blob->readString(); // ! don't need to use .get() ("->" and ".get()->" are the same things)
	Log::warning("Received: %s\n", str.get()); // ! but, with Log::warning/message you should use .get() for strings, yes
			syncker_manager->getSlave()->setTCPUserReceiveCallback(MakeCallback(this, &AppWorldLogic::tcp_user_receive)); // !
				BlobPtr blob = Unigine::Blob::create(); // !
				blob->seekSet(0); // ! reset current position to the beginning
Best regards,
Alexander
"In future releases i will do it for you automatically."
Sorry, it was a bug. Calling seekSet(0) will help you if you have only one slave.
If you have more than one slave then the workaround is:
auto master = syncker_manager->getMaster();
for (int i = 0; i < master->getNumSlaves(); i++)
	int mask = 1 << i;
	blob->seekSet(0);
	master->sendTCPUser(mask, blob);
Thanks alex ! :)
Do you mean the seekSet(0) won't be needed in the future ? Or do you mean the for-loop won't be needed? Does this bug also exist for all other api using a mask to communicate with the slaves?
Do you mean the seekSet(0) won't be needed in the future?
Yes! In SDK v2.7.2.
I mean you will be able to do it as you wrote before (without seekSet() and for-loop):
No. It was only inside the sendTCPUser() method of Master and Slave classes (hope so).
Best regards,
Alexander
Sorry to bother, but this line does not compile :(
1>c:\tools\dev\unigine sdk browser\sdks\sim_per_channel_windows_2.7.1\include\UnigineCallback.h(451): error C2530: 'Unigine::CallbackObject1<Class,Ret (__cdecl AppWorldLogic::* )(A0),A0>::a0' : les références doivent être initialisées
1>          with
1>          [
1>              Class=AppWorldLogic,
1>              Ret=void,
1>              A0=Unigine::BlobPtr &
1>          ]
1>  c:\tools\dev\unigine sdk browser\sdks\sim_per_channel_windows_2.7.1\include\UnigineCallback.h(451): note: lors de la compilation de la fonction membre '<Inconnu>' de la classe <Inconnu>
1>  c:\tools\dev\unigine sdk browser\sdks\sim_per_channel_windows_2.7.1\include\UnigineCallback.h(561): note: voir la référence à l'instanciation de la fonction modèle 'Unigine::CallbackObject1<Class,Ret (__cdecl AppWorldLogic::* )(A0),A0>::CallbackObject1(Class *,Func)' en cours de compilation
1>          with
1>          [
1>              Ret=void,
1>              A0=Unigine::BlobPtr &,
1>              Func=void (__cdecl AppWorldLogic::* )(Unigine::Ptr<Unigine::Blob> &)
1>          ]
1>  c:\tools\dev\unigine sdk browser\sdks\sim_per_channel_windows_2.7.1\include\UnigineCallback.h(561): note: voir la référence à l'instanciation de la classe modèle 'Unigine::CallbackObject1<Class,Ret (__cdecl AppWorldLogic::* )(A0),A0>' en cours de compilation
1>          with
1>          [
1>              Ret=void,
1>          ]
1>  AppWorldLogic.cpp(90): note: voir la référence à l'instanciation de la fonction modèle 'Unigine::CallbackBase1<Unigine::BlobPtr &> *Unigine::MakeCallback<AppWorldLogic,void,Unigine::BlobPtr&>(Class *,Ret (__cdecl AppWorldLogic::* )(A0))' en cours de compilation
1>          with
1>          [
1>              Ret=void,
1>          ]
(I really don't understand this error, because I use successfully the MakeCallback macro elsewhere for Cigi callbacks).
Oops.
Change this:
to this:
void AppWorldLogic::tcp_user_receive(BlobPtr blob) // remove '&'
