Amerio.Stephane Posted June 19, 2018 Posted June 19, 2018 Hello, For calibration purpose, I need to superimpose a special reticule (a grid-like object) on the rendered screen*. I can do this easily by creating a custom object, assigning it a cigi type, and parenting it to the cigi ownship with a Cigi entity message. Problem is: I must not do it through cigi messages, because I must show/animate the reticule even when no host is active. On the master, I can get the parent node of the Cigi player and manually attach my own reticule. I also called addSyncNode with the reticule and the syncker. But on the slaves, the reticule doesn't look like it's linked to the ownship. Any ideas? *Think of the reticule as something drawn on the windshield of an helicopter, hence linked to the helicopter itself, not linked to the view/pilot's eye.
alexander Posted June 20, 2018 Posted June 20, 2018 Hi, Try to use addSyncNode with the parent node of the Cigi player also. The thing is Cigi add to sync only root nodes (NodeDummies + NodeReferences for each Entity/View), but the inner hierarchy (for performance reasons) does not have a link "Master ID -> Slave ID" (all nodes created at run time have random IDs). So, when Slave try to sync your reticule, it can not find a parent node with such ID. Best regards, Alexander
Amerio.Stephane Posted June 20, 2018 Author Posted June 20, 2018 Hi alex, I added the parent node of the cigi player and it worked ! Thanks ! Now, I also need to have it when I switch from the cigi camera to my free roaming camera. While I can switch camera thanks with the code provided below, my reticule ("calib") is now only syncked in cigi mode. Here is the code: int AppWorldLogic::init() { spectator = PlayerSpectator::create(); spectator->setZFar(200000.0f); spectator->setMinVelocity(50.0f); spectator->setMaxVelocity(500.0f); cigi_player = Game::get()->getPlayer(); // save current CIGI camera calib = Editor::get()->getNodeByName("Calib"); if (calib.get()) { NodePtr cigi_parent = cigi_player->getParent(); if (cigi_parent.get()) calib->setParent(cigi_parent); int syncker_index = Engine::get()->findPlugin("Syncker"); if (syncker_index != -1) { Syncker::ManagerInterface* syncker_manager = (Syncker::ManagerInterface*)Engine::get()->getPluginData(syncker_index); if (syncker_manager->isMasterInitialized()) { Syncker::MasterInterface* syncker = syncker_manager->getMaster(); syncker->addSyncNode(calib); syncker->addSyncNode(cigi_parent); // these two lines don't help :( syncker->addSyncNode(spectator->getNode()); syncker->addSyncNode(spectator->getPlayer()->getNode()); } } } return 1; } int AppWorldLogic::update() { // switch the camera by press the SPACE button if (App::get()->clearKeyState(' ') && !Console::get()->getActivity()) { is_cigi_player = !is_cigi_player; if (!is_cigi_player) { Log::message("Spectator player\n"); // switch to manual camera spectator->setWorldTransform(cigi_player->getWorldTransform()); // make position and rotation of our camera the same as the CIGI camera Game::get()->setPlayer(spectator->getPlayer()); // set to our camera calib->setParent(Game::get()->getPlayer()->getNode()); calib->setRotation(Math::quat(270, 0, 0)); } else { Log::message("CIGI player\n"); // switch to automatic CIGI camera Game::get()->setPlayer(cigi_player); NodePtr cigi_parent = cigi_player->getParent(); if (cigi_parent.get()) { calib->setParent(cigi_parent); calib->setRotation(Math::quat(0, 180, 90)); // for some reason, the base rotation is different between cigi and spectator (?) } } } return 1; } What am I missing?
alexander Posted June 20, 2018 Posted June 20, 2018 // these two lines don't help :( Hi. You need to call Master::createNode() to all dynamically created nodes (at run time, not in the Editor) if you want to sync them between machines.Unigine's Documentation: createNode method So, // these two lines don't help :( syncker->addSyncNode(spectator->getNode()); syncker->addSyncNode(spectator->getPlayer()->getNode()); // this line should help you syncker->createNode(spectator->getNode()); // for some reason, the base rotation is different between cigi and spectator (?) Yeah, CIGI uses X axis as Forward, Y axis as Right and Z as Down. Unigine uses X as Right, Y as Up and Z as Back for the player nodes. Best regards, Alexander
