Amerio.Stephane Posted June 5, 2018 Posted June 5, 2018 Hello, Is it possible to temporarily regain manual "flight" control during a CIGI session (through custom code/script)? Use case: During a flight session, we may need to "flight with keyboard and mouse" to reckon the terrain, prepare the mission or simply debrief. In our current IG, with a key press, with toggle between network CIGI control and mouse control. Can a similar behavior be coded ? Thanks.
alexander Posted June 5, 2018 Posted June 5, 2018 Hi Amerio, Yes, of course! You need to make a "Player switcher": a switcher between the current Player (made by CIGIClient) and your PlayerSpectator (which can be controlled by keyboard/mouse). Here is a sample code for this feature: AppWorldLogic.h: #include <UniginePlayers.h> //... class AppWorldLogic : public Unigine::WorldLogic { private: Unigine::PlayerSpectatorPtr spectator; // your Player that can be controlled by keyboard/mouse Unigine::PlayerPtr default_player; // in your case, it is a Player created by CIGI Client // ... }; AppWorldLogic.cpp: #include <UnigineApp.h> #include <UnigineConsole.h> #include <UnigineGame.h> using namespace Unigine; int AppWorldLogic::init() { // create and set up your Player spectator = PlayerSpectator::create(); spectator->setZFar(200000.0f); // set far clip plane (200 km, for example) spectator->setMinVelocity(50.0f); // set camera speed when you use WSAD/QE keys (50 m/s) spectator->setMaxVelocity(500.0f); // set camera speed when you hold SHIFT key (500 m/s) // ... return 1; } int AppWorldLogic::update() { // switch the camera by press the SPACE button if (App::get()->clearKeyState(' ') && !Console::get()->getActivity()) { PlayerPtr current_player = Game::get()->getPlayer(); if (!current_player || current_player != spectator) { // switch to manual camera default_player = current_player; // save current CIGI camera spectator->setWorldTransform(current_player->getWorldTransform()); // make position and rotation of our camera the same as the CIGI camera Game::get()->setPlayer(spectator->getPlayer()); // set to our camera } else // switch to automatic CIGI camera Game::get()->setPlayer(default_player); } return 1; } Best regards, Alexander 1
Amerio.Stephane Posted June 6, 2018 Author Posted June 6, 2018 Hi, thanks a lot for the code snippet ! (I had to modify it a bit because VS2015 could not find the '!=' operator PlayerPtr, though.)
