[SOLVED] Raw data from socket
Hi!
I have QT app, which send me some data. I need this data in raw (i.e. in HEX, not ASCII or smt else). How can I do this through Unigine API? For test I'm using usage example from documentation (ClientSocket class only, C++): I've recieved messages in this form - "Z4�w|" - but I need this - "5a 34 f9 77 7c 03 00 00 43 4f 52 42 41 54 48 59 03 00 00 00 00 00 00 00 00 00 59 40 1c 00 00 00 cf 02 00 00 fb 51 04 de d0 06 4e 40 a1 f8 31 e6 ae 75 3d 40 00 00 34 43 00 00 00 ..." (892 bytes total).
Hi!
It seems, that you are reading incoming data not entirely correct.
If you are trying to show debug data via Log::message() it will try convert bytes to string first and also will stop at null symbol received ('\0', HEX = 00).
You can try this code to output raw data:
for (size_t i = 0; i < data_size; ++i)
  Log::message("%x ", data[i]);
Oh, I forget about %x, what a stupid mistake. Thanks, everything ok now!
  • silent changed the title to [SOLVED] Raw data from socket
