manuel.gysin Posted April 18, 2011 Share Posted April 18, 2011 Hi I think we all find some wrong information in the documentation. Such a thread may be a good point to tell it to unigine so they can correct it and we all gain a better documentation. So lets start: Source:https://developer.unigine.com/en/docs/1.0/code/gui/ui_widgets Part: vslider and hslider Correction: <hslider name="Test::vslider" export="1" align="expand" min="0" max="1000" value="500" height="100" button_height="30"> <attach format="Value: %.1f" [b]multiplier="1000"[/b]>vslider_label</attach> </hslider> <label name="vslider_label" width="70"/> and <hslider name="Test::hslider" export="1" align="expand" min="500" max="3500" value="1000" width="100" button_width="30"> <attach format=" %.1f" [b]multiplier="1000"[/b]>hslider_label</attach> </hslider> <label name="hslider_label" width="28"/> Multiplier is used as integer and not as float. Result is divided and not multiply through it. Correction: Vslider shows a hslider as example (Source code (XML)). Source:https://developer.unigine.com/en/docs/1.0/getting_started/console Part: General Settings Correction: video_app can also return direct3d11. Greets Manuel PS: Thanks for the online manual! It helps a lot, had so much troubles with the chm file. :( Link to comment
manguste Posted April 19, 2011 Share Posted April 19, 2011 Thank you very much, Manuel. Fixed. Link to comment
