Corvax Posted April 27, 2018 Posted April 27, 2018 After migrating to version 2.7 repositioning of billboards in my application has drastically slowed done. Actually it's about 20 times slower than in version 2.6.1.1. Here is the code start = std::chrono::high_resolution_clock::now (); for ( int id = 0; id < pBillboadrs->getNumBillboards (); id++ ) { double dRadius = fFarClipping-150.0; int iStarID = mapBillboardID2StarID[id]; double x, y, z; y = dRadius * StarSky[iStarID].ObservParam.Alt.cos () * StarSky[iStarID].ObservParam.Az.cos (); x = dRadius * StarSky[iStarID].ObservParam.Alt.cos () * StarSky[iStarID].ObservParam.Az.sin (); z = dRadius * StarSky[iStarID].ObservParam.Alt.sin (); Math::vec3 position ( x, y, z ); pBillboadrs->setBillboardPosition ( id, position ); } end = std::chrono::high_resolution_clock::now (); auto lag = std::chrono::duration<double, std::ratio<1, 1>> ( end - start ); char str[128]; sprintf_s ( str, 128, "StarSky: 'setBillboardPosition' for %i billboards in %f seconds\n", pBillboadrs->getNumBillboards (), lag.count () ); Log::message ( str ); Number of billboards is 7987. Loop execution time is 0,082163 seconds for version 2.6.1.1 and 1,46314 seconds for vesion 2.7. All math in loop is OK. If I comment line with setBillboardPosition the loop is very fast in all versions. The same problem is with billboards size change. Simular code for changing size has become very slow.
silent Posted April 28, 2018 Posted April 28, 2018 Hi Corvax, Thank you for the test code, will try to improve this behavior in 2.7.1. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
silent Posted June 14, 2018 Posted June 14, 2018 Should be already fixed in 2.7.1. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
