Amerio.Stephane Posted April 25, 2018 Share Posted April 25, 2018 (edited) Hello, I created an impostor with 4 rows and 4 columns (remaining settings left to default) for the iconic material_ball. To better visualize impostor selection, I colorized each row: As you can see here, the last row is not used by the billboards (viewed from above): (left: billboard, right: the iconic material_ball object) Attached: material and textures:Impostor.zip (edit: attached the correct zip file) Edited April 25, 2018 by Amerio.Stephane Link to comment
Amerio.Stephane Posted April 25, 2018 Author Share Posted April 25, 2018 Note that the grass_impostor_base material *does* use the last row of the image. But billboards_impostor_base doesn't :( Link to comment
morbid Posted April 25, 2018 Share Posted April 25, 2018 Yes, you're right, it's a bug. impostor_base ignores the 4th row. I'm afraid we can't afford to fix this in the upcoming release. 2.7.1 seems more real. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Amerio.Stephane Posted April 25, 2018 Author Share Posted April 25, 2018 No trouble :) As an additional request, maybe you could add the possibility for billboards_impostor_base to also support blending between images, just like grass_impostor_base? And one more question: the impostor images are generated with size 1/1.418, wasting a lot of empty room around the actual images. Is there a particular reason for that? Thank you ! Link to comment
vvvaseckiy Posted May 10, 2018 Share Posted May 10, 2018 Hello Amerio.Stephane, Your issue is fixed, the fix will come in upcoming 2.7.1 release. I've also added your feature request to our internal tracker, but unfortunately can't give you any ETA on when it will be implemented. Empty space in impostor images is just padding used for filtering one image from another in single texture. Thank you for your feedback Link to comment
morbid Posted May 30, 2018 Share Posted May 30, 2018 By the way, we've added Lerp (blending) for impostor_impostor_base material. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Amerio.Stephane Posted May 30, 2018 Author Share Posted May 30, 2018 Great news ! Thanks a lot :) Link to comment
