WorldTrigger Problem/Question
I have a Problem by managing TriggerCallbacks. They dont want to work in my Case.
Here my Example:
Class Test {
Node myTriggerNodeArray[0] = ();
WorldTrigger myTrigger;
Test (
myTrigger = new WorldTrigger(myNode.getBoundMax());
myTrigger.setTouch(1);
myTrigger.setEnterCallback("CollissionDetected");
myTrigger.setLeaveCallback("CollissionLeaveDetected");
myTrigger.setName("attach_trigger");
void CollissionDetected()
 Logger::logger (0, "Test::CollissionDetected()", "CollissionDetected" );
void CollissionLeaveDetected()
Logger::logger (0, "Test::CollissionLeaveDetected()", "CollissionLeaveDetected" );
PlaceNode()
myNode.setPosition(myPosition);
myTriggerNodeArray.append(myNode);
myTrigger.setTargetNodes(myTriggerNodeArray);
So i have my Oject Test in the running CPP-File and i place a node, about PlaceNodefunction. So i add this to my Targetnodes from the Trigger.
In my Constructor i managed the Callbackdeclaration.
When i now place a node in another Target node the event dont react. And i dont know why. I can use WorldTrigger´s for Collissiondetection or?
Greets Jochen
Not sure what you want to achive exactly but if you are interested in inter-node collisions than maybe you better should use Body class based collision detection instead of WorldTrigger.
Just from a coding point of view I would expect that callback functions and myTriggerNodeArray should be declared on a global scope. Also WorldTrigger size and position should be properly synchronized and you should ensure proper trigger/node removal on class destruction to avoid memory leaks. Something like
// global scope
Node g_myTriggerNodeArray[0];
void CollissionDetected( Node node )
void CollissionLeaveDetected( Node node )
// class scope
Class Test {
   Test
       vec3 triggerSize =  myNode.getBoundMax() - myNode.getBoundMin();
       // you could deferre WorldTrigger creation to placeNode()
       myTrigger = new WorldTrigger(triggerSize); // bounMax() is proper size only if bindMin() = vec3(0,0,0)
   placeNode()
      myNode.setPosition(myPosition);  // I would expect that you would also have to update WorldTrigger pos
      myTrigger.setPosition( myPosition );
      g_myTriggerNodeArray.append(myNode);
   // also ensure proper myNode removal from myTriggerNodeArray and myTrigger destruction on Test class destruction
   removeNode()
      int index = g_myTriggerNodeArray.find(myNode);
      if( index != -1 ) {
          g_myTriggerNodeArray.remove(index);
   ~Test()
       removeNode();
       if( myTrigger != 0 ) {
           delete myTrigger;
Edit: Miss understood the documentation. :(
Jochen and me tried today to implement this, but something is very strange.
project.cpp (Version 1 with no global scope)
int init() {
   WorldTrigger myTrigger2 = new WorldTrigger(vec3(5,5,5));
   Node test_trigger_targets[2];
   Node tmpNode = node_load("relics_of_annorath/nodes/trees/fraser_fir_001.node");
   Node tmpNode2 = node_load("relics_of_annorath/nodes/trees/fraser_fir_002.node");
   Node tmpNode3 = node_load("relics_of_annorath/nodes/flora/mushrooms/mushroom_001.node");
   test_trigger_targets.append(tmpNode);
   test_trigger_targets.append(tmpNode2);
   test_trigger_targets.append(tmpNode3);
   myTrigger2.setTargetNodes(test_trigger_targets);
   log.error("Target Nodes: %i \n", myTrigger2.getNumNodes());
This will return 0 in the log.error.
project.cpp (Version 2 with global scope)
int init() {
This will return always 1 in log.error.
I don't understand this, are we doing something horrible wrong?
