World::get()->getIntersection() problems
Hi, when I used World::get()->getIntersection(controller[num]->getWorldBoundBox(), intersections) to detect intersections objects
Sometimes, even my controller has already collided with the objects, but in the Vector<Objptr> intersections, I still couldn't detect the object. (I printed all the obj, but the target object doesn't show)
as the picture below shows, the controller already collides with the hook.
And if I changed the hook's position (such as rotating the winch) or the helicopter's position (the vive tracker), it will detect the hook again. it seems only in some areas or angles that the intersection can't detect properly. The correct scenario should be like this:
and the malfunction phenomenon happens randomly, and really boring
are there anything I missed or need to pay attention to when using  World::get()->getIntersection() ?
Thanks
Hi Lukas,
For debugging purposes you can try to visualize object's bounds and controller ray to find out what is really happens. Maybe adding some more rays or extending their length will also help.
If you can prepare a really small test example on a blank world - we can check more closely.
AppWorldLogic::init :()
Visualizer::get()->setEnabled(1);
AppWorldLogic::update()
 Visualizer::get()->renderNodeBoundBox(Editor::get()->getNodeByName("door_handle"), vec4(1.0f, 0.0f, 0.0f, 1.0f));
Does this work in VR environment? I cannot see any bound box in VR .
Lukas,
You can try to grab AppVive plugin (dll) from the 2.6.1.1 SDK. Visualizer is fixed in this build. Or you can manually rebuild the AppVive plugin and add following line in source/plugins/App/AppVive.cpp:
viewport->setSkipFlags(0);
after
viewport = Viewport::create();
at line 87.
