[SOLVED] Can't move around
We received a Unigine world from a subcontractor. The world is fine however when you "run" it you can't move around using WASD. I have tried adding a PlayerActor in AppWorldLogic::init() but it makes no difference.
    player = Unigine::PlayerActor::create(); // I have also tried a PlayerSpectator instead of PlayerActor
    player->setWorldPosition(Math::vec3(0,0,20));
    Game::get()->setPlayer(player->getPlayer());
It does set the player's initial position to Z+20 so I can see that its' run, but nothing I do seems to allow movement.
Do you have any idea where I can look?
Unigine 2.6.0.1, Editor2
Hi Angus,
The first thing I would check, is whether the game logic is paused or not. You can do that by adding the following lines to your code after setting a player :
	if (Game::get()->isEnabled())
		Log::message("Game enabled!");
	else
		Log::message("Game disabled!");
If the answer is "Game disabled", and it was not disabled by you intentionally, then most likely your  *.world file was saved with the Play button released.
You can check the *.world file for the following:
<game>
	<enabled>0</enabled>
</game>
You can try to fix the problem by change 0 to 1 manually in the *.world file, or you can open your world in  the editor, press the Play button and save your world.
Hope this helps!
  • silent changed the title to [SOLVED] Can't move around
