Klimczak.Jan Posted December 12, 2017 Share Posted December 12, 2017 Hi, I Observed that Run in SDK Browser 1.8.2 starts PROJECT_NAME.exe file but Edit Content starts main.exe (here you should add x86, x64 and d for provided names). I assume that this should point for the same file as start point. Link to comment
paralyzah Posted December 14, 2017 Share Posted December 14, 2017 Hello. The work of custom (c++ / c#) applications with Editor2 is on development stage and for now Editor2 will always start with main_x**.exe default application to avoid any unstable behavior. You can use console command editor2_load in running application (please, don't forget to pass -extern_plugin "Editor2"), but this does not guarantee stability if the c++ / c# application uses complicated logic. Sorry for the inconvenience caused. 1 Link to comment
