L.witko Posted April 8, 2011 Share Posted April 8, 2011 Hi, is there a way to load render settings (scattering) from a .world file? It has the same <render>...</render> tag as .settings file, but engine.render.loadSettings(string file) generates error: "Render::loadSettings(): bad settings file". Link to comment
ulf.schroeter Posted April 8, 2011 Share Posted April 8, 2011 Hi, is there a way to load render settings (scattering) from a .world file? It has the same <render>...</render> tag as .settings file, but engine.render.loadSettings(string file) generates error: "Render::loadSettings(): bad settings file". render settings within .world file will be automatically loaded on world load. If you want to load these settings via engine.render.loadSettings(string file), you can copy and paste them into seperate .settings XML file with following required structure. <custom_render.settings> <?xml version="1.0" encoding="utf-8"?> <settings version="1.00"> <render> // copy and past render settings from a world file here </render> </settings> Link to comment
