eugene.litvinov Posted April 5, 2011 Share Posted April 5, 2011 I have class: class BaseObject { private: Node node; public: BaseObject() { } ~BaseObject() { } void init(Node node) { this.node = node; node.setData(this); } string getName() { return node.getName(); } Node getNode() { return node; } vec3 getPosition() { return node.getPosition(); } vec3 getRotation() { return node.getRotation(); } vec3 getScale() { return node.getScale(); } void setName(string value) { node.setName(value); } void setNode(Node value) { if (node != NULL) node.setData(NULL); node = value; node.setData(this); } void setPosition(vec3 value) { node.setPosition(value); } void setRotation(vec3 value) { node.setRotation(value); } void setScale(vec3 value) { node.setScale(value); } void shutdown() { } void update(float dt) { } }; and have next call: BaseObject baseObject = new BaseObject(10, "---"); this cause error: 09:38:50 BaseObject baseObject = new BaseObject(10, "---"); 09:38:50 source/maps/test.cpp:50: Parser::readName(): bad name '1' this is right. But, if I don't declare default constructor, the error don't appear, and if we inherit BaseObject from, for example, TestClass and has constructor in it: TestClass() { // constructor without parameters } the error don't appear too. Link to comment
serega Posted April 8, 2011 Share Posted April 8, 2011 Thanks. We found one more problem - the error message will be different depending on the number of arguments. Link to comment
eugene.litvinov Posted June 30, 2011 Author Share Posted June 30, 2011 If I define constructor in base class, and don't define it in derived class, then constructor don't call at all. Constructor in base class calls only if I define constructor in derived class too: TestClass() { __BaseClass__(); } Your Unigine script is more functional than OOP-oriented, I'm using Unigine more that half year, and during this time you did't do anything to improve you script OOP system, this is sad ( Link to comment
manguste Posted July 22, 2011 Share Posted July 22, 2011 If I define constructor in base class, and don't define it in derived class, then constructor don't call at all. Constructor in base class calls only if I define constructor in derived class too: Fixed. Will be available in the next SDK update. Link to comment
