lightmap Posted September 13, 2017 Posted September 13, 2017 (edited) Hello in uscript I load skinned mesh and then it must be casted to NodeReference in documentation I found nothing about how to cast ObjectMeshSkinned to NodeReference - it is not obvious for me ObjectMeshSkinned SM = new ObjectMeshSkinned("SM.mesh"); Node N_SM = SM; NodeReference NR_SM = new NodeReference(????); it will be very helpful if I can refer to some table with possible conversions between types - does that table/map/list exist? thanks Edited September 14, 2017 by lightmap
lightmap Posted September 14, 2017 Author Posted September 14, 2017 https://developer.unigine.com/en/docs/2.5/api/library/nodes/class.nodereference?rlang=usc&words=nodereference%2Cnoderefer#highlight NodeReference cast(Node node) Casts a NodeReference out of the Node instance. and how to call cast()? NodeReference EX = ?cast?(Node)
fox Posted September 14, 2017 Posted September 14, 2017 Hello lightmap! If I get you right, you are trying to do something like this: /* ... */ ObjectMeshSkinned mesh_skinned = new ObjectMeshSkinned("yourmeshname.mesh"); /* ... */ NodeReference nodref; /* ... */ noderef = class_cast("NodeReference", mesh_skinned); The class_cast() function performs conversions between pointers to related classes, not only upcasts (from pointer-to-derived to pointer-to-base), but also downcasts (from pointer-to-base to pointer-to-derived). No checks are performed during runtime to guarantee that the object being converted is in fact a full object of the destination type. Therefore, it is up to the programmer to ensure that the conversion is safe. It is true that both NodeReference and ObjectMeshStatic classes have the same parent class - Node. But the fact that two classes A and B have the same base-type does not make them interchangeable; an A is always an A, and a B is always a B. So I'm afraid such casting cannot be performed. A NodeReference is a node that refers to an external *.node file on the disk. The only thing you can do here is the following: 1) Create an ObjectMeshSkinned from the specified *.mesh file 2) Export it to my_node.node file 3) Create a NodeReference referring to the my_node.node file Here is an example (UnigineScript) with an ObjectMeshStatic illustrating the idea : #include <core/unigine.h> int init() { // create a mesh Mesh mesh = new Mesh(); mesh.addBoxSurface("box_0", vec3(1.0f)); // save a mesh into a file on the disk mesh.save("unigine_project/meshes/my_mesh.mesh"); // create an instance of any class inherited from the Node class (e.g. ObjectMeshStatic) ObjectMeshStatic object_mesh = new ObjectMeshStatic("unigine_project/meshes/my_mesh.mesh"); // assign a material to the mesh object_mesh.setMaterial("mesh_base","*"); // release script ownership node_remove(object_mesh); // pass node ownership to the editor by adding the node to it engine.editor.addNode(object_mesh); // export the node into a .node file engine.world.saveNode("unigine_project/nodes/my_node.node",object_mesh); // import the exported node to check the result NodeReference noderef = new NodeReference("unigine_project/nodes/my_node.node"); // set a position of the node noderef.setPosition(Vec3(4.0f, 0.0f, 1.0f)); return 1; } I hope this helps! If you have any more questions, don't hesitate to ask! Thanks! 1
lightmap Posted September 14, 2017 Author Posted September 14, 2017 Thank you fox, for detailed answer class_cast("NodeReference", mesh_skinned); does help
