esger.abbink_ Posted July 13, 2017 Share Posted July 13, 2017 in the documentation it is mentioned that: Physical triggers fire callbacks when one of following gets inside or outside of them: Physical objects. Non-physical collider objects. see also https://developer.unigine.com/en/docs/2.3/api/library/physics/class.physicaltrigger However, for non-physical collider objects I couldn't get this to work. The physical trigger did register contacts, but no callbacks were called. Did a little digging, and from the following code excerpt: void PhysicalTrigger::updateContacts() { // swap bodies bodies.swap(old_bodies); bodies.clear(); // get collision shape->getCollision(contacts,engine.physics->getIFps()); // update contacts for(int i = 0; i < contacts.size(); i++) { const Shape::Contact &c = contacts[i]; // shape contact if(c.shapes[1] != NULL) { Body *body = c.shapes[1]->getBody(); if((body->getPhysicalMask() & physical_mask) == 0) continue; Vector<Body*>::Iterator it = bodies.find(body); if(it == bodies.end()) { Vector<Body*>::Iterator it = old_bodies.find(body); if(it == old_bodies.end()) run_enter_callback(body); else old_bodies.remove(it); bodies.append(body); } } } // run leave callbacks for(int i = 0; i < old_bodies.size(); i++) { run_leave_callback(old_bodies[i]); } } It seems clear that indeed callbacks are only ever called if there is a collision involving a body. Note that c.shapes[1] is the shape of the other (not the trigger shape) and for a collider node this is always NULL (as it does not have a shape). The callback argument (BodyPtr body) also hints quite strongly to the same conclusion, but theoretically for a non body collision the parameter passed could have been NULL. This concerns version 2.3, but the documentation for 2.5 indicates no change. Link to comment
silent Posted July 14, 2017 Share Posted July 14, 2017 Hi Esger, Thanks for the information. We will check it and update documentation ASAP. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
fox Posted August 1, 2017 Share Posted August 1, 2017 Hi Esger, Indeed, currently callbacks are fired for physical objects only (i.e. with a body and a shape assigned). The documentation is updated. Maybe we'll add firing callbacks for non-physical objects later. Thanks for the information! Link to comment
