Switch from physical body to "static" collision
I need realize some logic, when I can enable/disable physical body of object, so in one time it be physical, and in another - this is only static mesh with "static" collisions.
I use NodeReference node in game, get it physical body of it inner Node, and use Body::setEnabled(false); - but in this case node has no collision with any object or player, but if I remove Body from NodeReference in Editor mode, save it and load in game, then I will have "static" collision.
Question: how can I switch from body collision to "static" mesh collision and back for my NodeReference node?
Set zero mass for all shapes.
Sorry, not understand, is next right?
NodeReference cube = new NodeReference("source/nodes/cube_blue.node");
cube.setPosition(pos);
Object innerObject = node_cast(cube.getNode());
BodyRigid body = innerObject.getBodyRigid();
for (int i = 0; i < body.getNumShapes(); i++)
Shape shape = body.getShape(0);
shape.setMass(0.0f);
body.setEnabled(false);
Cause it don't work :(
Have you tried it with body.setEnabled(true) ?
With body.setEnabled(true) it works. But I need disable Body, cause I need scale my object... I use unit scale, when I need to interact with physical object, and then in some moment I need to disable physical behavior, set different scale and leave object, but I need that another objects and player will collide with it. Then in some moment I need take this object, set unit scale and enable physical behavior.
Does sound a little bit complicated. As far as I know scaling for body shapes is not really supported. Anyway alternetivly you could provide 2 shapes (one unscaled and one scaled) and used appropriate Shape::setEnabled( true/false) calls based on game state.
I don't scale body shapes. I disable body, and scale object (mesh), when I enable body, it already the same, unit scale.
We can leave scale now, and it is all the same: when I disable physical body object not react like simple mesh with collision and intersection.
