helmut.bressler Posted May 9, 2017 Share Posted May 9, 2017 Hello Unigine Team, is it possible to get a 5th Viewport inside the Editor (i.e. by modifying some config file or some lines in the data/editor folder?) We really only need the 5th viewport during development, so I didn't look at how I could implement this with WidgetSpriteViewport. Thank you and cheers Helmut EDIT: Solved. It seems that the number of available viewports is defined by the length of the window names array in editor_viewports.h string window_names[0] = ( "Viewport 1", "Viewport 2", "Viewport 3", "Viewport 4", "Viewport 5", ); I cannot open the 5th viewport through the menu as shown in the screenshot but I can open all 5 viewports at startup through the unigine_editor.cfg: <item name="active_viewport_windows">Viewport 1,Viewport 2,Viewport 3,Viewport 4,Viewport 5</item> which is sufficient in our case. Link to comment
