Video grabber BG alpha mask
I would like to render a character using video grabber,
but the "background alpha mask" function does not seem to work.
I think this function is a function that generates alpha layer of rendered objects by alpha processing the background part,
and I want to know what conditions are necessary to use it.
You also can try to apply following settings to get correct alpha on a screenshots:
  1. Enable 16bit color format for the final image (Rendering -> Buffers -> Color 16F);
  2. Disable Environment (Rendering -> Features -> Environment);
  3. Modify Environment color: Rendering Settings (Alt + R) -> Common -> Background Color (set it to black and Alpha to 0 via sliders);
  4. Disable DOF (if enabled): Rendering -> Camera Effects -> DOF;
  5. Set Exposure mode to static: Rendering Settings (Alt + R) -> Camera Effects -> Exposure -> ModeStatic (adjust Exposure level to get more brighter picture).
