Customized materials
I try to create a customized material with some shaders.
As far as I know, the normal way is put a .mat file into a folder which is related with a .world file and so on.
after call the method:
Console::get()->run("world_load");
then the customized material has been loaded into engine.
Correspondingly, Console::get()->run("world_quit") can remove the material from engine
This mechanism works well.
But I intend to give the customized material longer lifetime, as long as the running engine instance, just like those default materials automatically loaded by engine. Regardless how many times worlds are loaded or quitted, the material still stick in engine. So I have to load my .mat file before the first world_load call.
I attempt to use some methods like:
pMaterials->addWorldLibrary(str);
pMaterials->load(str);
Unfortunatelly, Both return 0.
Thanks
Unigine core materials are loaded into the engine via script code in function init() in file <sdk-folder>/data/core/scripts/system/system.h.
void init(string name_,string languages_[],string locales_[]) {
// load materials
engine.materials.load("core/materials/default/unigine_post.mat");
engine.materials.load("core/materials/default/unigine_render.mat");
engine.materials.load("core/materials/default/unigine_decal.mat");
engine.materials.load("core/materials/default/unigine_decal_terrain.mat");
So I would expect that usage of pMaterials->load() should do the trick.
Any error messages within Unigine log file indicating some load issue with your material library (e.g. invalid material definition, file not found, etc) ? For testing purposes you can temporarily add your custom material library load operation to the system script code  just to check if it is generally loadable.
Hi Ulf,
I DID find a file by the name of <sdk-folder>/data/core/scripts/system/system.h, but I didn't find anything associated with loading materials.
The Init() method looks like this:
void init(string name_, string languages_[], string locales_[])
	name = name_;
	languages.copy(languages_);
	locales.copy(locales_);
	toggle = APP_KEY_ESC;
	language = -1;
	// splash parameters
	splash_4x3_name = "core/gui/splash.png";
	splash_16x9_name = "core/gui/splash.png";
	splash_transform = vec4(0.5f, 0.33f, 0.5f, 0.5f);
	splash_color = engine.gui.parseColor("0c0c0c");
	splash_text = "<p align=center><font color=#606060 size=16><xy y=%100 dy=-20/>UNIGINE Corp. (c) 2005-2017</font></p>";
	splash_threshold = 16;
// export locale
#ifdef EXPORT_LOCALE
	if (locales.size())
		string tokens[0];
		if (strsplit(locales[0], ":", tokens) == 2)
			engine.gui.saveDictionary(tokens[0], tokens[1]);
		else
			engine.gui.saveDictionary(locales[0]);
#endif
// export extern
#ifdef EXPORT_EXTERN
	File file = new File();
	if (file.open("extern_info.h", "wb"))
		file.puts(get_extern_info(EXPORT_EXTERN));
		file.close();
	delete file;
#endif
	// initialize window
	user_interface = new UserInterface(engine.getGui(), name);
#ifndef HAS_INTERFACE
	engine.gui.addChild(main_w, GUI_ALIGN_CENTER | GUI_ALIGN_OVERLAP);
	engine.gui.removeChild(main_w);
#endif
	// set language
	set_language(engine.config.getInt("system_language", 0));
	// initialize tabs
	foreach (string tab; tab_prefix)
		call(tab + "init");
		call(tab + "update");
	// update language
	if (language_cb != NULL)
		update_language();
Ah, sorry, only had access to Unigine 2.0 sources yesterday evening. At least for 2.4 the code for default material library loading now has been move to the engine C++ code in Engine.cpp, so no longer customizable by script modification. Nevertheless also in C++ engine.materials.load(<librarypath>) is used.
Therefore I would still try to verify that your own material loads without any problems when included in some world file. Also make sure that the data path where your library is located is actually visible for the engine FileSystem class. Also check the log for any error message
Anyway, I have already loaded my material file into the engine :) .
If the .mat file has any semantic mistake, the console will report it to me.
	</material>
  <material name="customized_forward_material" editable="0">
    <options transparent="2"/>
    <state name="ambient">1</state>
    <shader pass="ambient" object="mesh_static"
			ambient="1"
			defines="BASE_AMBIENT"
			vertex="data/shaders/vertex/ambient.vert"
      fragment="data/shaders/fragment/ambient.frag"/>
        <bind object="mesh_dynamic" to="mesh_static"/>
        <bind object="mesh_skinned" to="mesh_static"/>
        <texture unit="0" name="albedo" anisotropy="1" shader="fragment" pass="deferred,ambient">unknown.dds</texture>
        <texture unit="1" name="height" shader="all" pass="deferred,ambient">unknown.dds</texture>
        <texture unit="2" shader="fragment" type="opacity_depth"/>
        <texture unit="3" shader="fragment" type="gbuffer_normal"/>
  </material>
After loading the .mat I can inheritMaterial new materials from the "customized_forward_material".
	VERIFY(pMaterials->load("uni_materials/materials.mat"));
	VERIFY(pMaterials->inheritMaterial("custom_forward_material", "uni_materials/materials.mat", strMaterial));
Now the problem is:
Actually I appointed two shader files in the .mat file:
But the key point is: either I write any meaningless words to the shader files or type wrong shader file names in .mat, the console dosen't give me any report about it.
In another word, I don't know how to get the shaders compilation outcomes.
I try to figure out some clues from the sample "ComputShaderImage". I type in some semantic mistakes into the shader file "compute_read_write.comp". I can get error reports only when the AppWorldLogic::update takes effect.
class AppWorldLogic : public WorldLogic
	virtual int update()
/* //If I disable the following codes, then no shader file(.comp) compilation outcome persents out.
               Render *render = Render::get();
		// Create resources if invalid
		create_resources();
		if (render->isFirstFrame())
			RenderState *state = RenderState::get();
			texture_render->setColorTexture(0, dynamic_texture);
			texture_render->enable();
			state->setBufferMask(0, RenderState::BUFFER_ALL);
			state->clearBuffer(RenderState::BUFFER_ALL, vec4::ZERO, 0.0f);
			texture_render->disable();
			texture_render->unbindColorTexture();
		float ifps = Game::get()->getIFps();
		int id = compute_material->findParameter("ifps");
		compute_material->setParameterSlider(id, ifps);
		// Set unordered access textures for compute shader
		texture_render->setUnorderedAccessTexture(0, dynamic_texture, 0);
		texture_render->enable(TextureRender::USAGE_COMPUTE);
		// Dispatch 32x32 (1024) group threads (each group has 32x32 (1024) threads, this value defines in compute shader file)
		int group_threads_x = 1024 / 32;
		int group_threads_y = 1024 / 32;
		// If incomplete group exist
		render->renderComputeMaterial(compute_material, group_threads_x, group_threads_y);
		texture_render->unbindUnorderedAccessTexture();
Hi
I have loaded the customized material into engine with shaders as well :) . I can get different outcomes when I modify shader codes, which testifies It works.
Acturally my demand is quite simple: create a rectangle mesh with the customized material, which is supposed to show out what the original texture exactly is.
This is the .frag file:
#include <core/shaders/common/fragment.h>
INIT_TEXTURE(0, TEX_COLOR)// Adds a texture sampler
// Input data struct
STRUCT(FRAGMENT_IN)
 INIT_POSITION    // Projected position
 INIT_IN(float4,0)   // Texcoord (uv)
END
MAIN_BEGIN(FRAGMENT_OUT,FRAGMENT_IN)
 float4 texcoord = IN_DATA(0);// Get the UV coords
 OUT_COLOR = TEXTURE(TEX_COLOR,texcoord.xy);// Get the texture data
MAIN_END
For some reasons, the outcome is kind of similar to the original texture, but the hue and saturation are not exactly the same.
I guess maybe It is causted by some post effects. So I turn off some render config options, like:
	pConsole->run("render_filmic 0");
But the differences are still obvious.
