denis.isakov Posted March 28, 2011 Share Posted March 28, 2011 Доброго времени суток. Используя инструмент для создания как карт нормалей, так и эмбиентов, столкнулся с проблему, что все страшно виснет. FPS не поднимается выше одного, что с этим можно сделать? Спасибо за ответы! Good day. Using a tool to create as normal maps and as ambient occlusion maps, faced with the problem that all the scary hangs. FPS does not rise above one, that this can be done? Thank you for your answers! Link to comment
alexander.zubov Posted February 4, 2012 Share Posted February 4, 2012 First of all, FPS stands for First-Person Shooter and fps stands for frames per second. This is the only forum I see people misusing FPS/fps abbreviations. Second, why do you care for fps when you are _baking_ maps? When maps are baked, CPU/RAM is used intensively. So you are better off grabbing a cup of tea and watching TV or surfing the Net, while normals / ao maps are being baked. That's normal and it happens with any app for baking normal/ao maps. Link to comment
