Akshay.Patil Posted March 8, 2017 Share Posted March 8, 2017 I am getting "OpenGL error: invalid operation" in console How can we debug this , is it the issue with engine or our app ? what we are doing , migration from Unigine 1 to Unigine 2.3.1? 1) Our material looks like this <material name="abc_custom_material"> <blend src="src_alpha" dest="one_minus_src_alpha"/> <state name="deferred">0</state> <state name="light_spot">0</state> <state name="light_omni">0</state> <state name="light_proj">0</state> <state name="light_world">0</state> <options object="mesh_dynamic" glow_mask="0" transparent="2" parallax_mask="0" cast_shadow="0" receive_shadow="0" cast_world_shadow="0" receive_world_shadow="0" receive_translucent="0"/> <shader pass="ambient" object="mesh_dynamic" defines="BASE_AMBIENT" alpha_test_defines=",ALPHA_TEST" vertex="shaders/abc_custom_material.vert" geometry="abc_custom_material.geom" fragment="abc_custom_material.frag"/> <parameter name="vectorX" type="expression">vec3(1.0f,0.0f,0.0f)</parameter> <parameter name="vectorY" type="expression">vec3(0.0f,1.0f,0.0f)</parameter> <parameter name="vectorZ" type="expression">vec3(0.0f,0.0f,1.0f)</parameter> <parameter name="xyz_color" type="color" shared="1">1 1 1 0</parameter> <parameter name="around_z" shared="1">0 0 0 0</parameter> <parameter name="abc_color" type="color" shared="1">1 1 1 0</parameter> </material> Is the material file correct ? is syntax <parameter name="vectorX" type="expression">vec3(1.0f,0.0f,0.0f)</parameter> still valid in Unigine 2.3.1 ? Link to comment
