[SOLVED] InterfaceWindow not showing widgets
In our application we are popping out some widgets into separate window something like this:
//PopoutWindow.h
Widget m_content; //not working
Widget test; //working
PopoutWindow( Widget content )
      m_content = content;
      test = new WidgetButton(gui, "test button");
      //create new InterfaceWindow
void SetWindowDockMode( int mode )
    Gui gui = engine.getGui();
    if( mode == WindowMode_Docked )
        m_externalGui.removeChild( m_content );
        m_externalGui.removeChild( test);
        gui.addChild( m_content, GUI_ALIGN_OVERLAP );
        gui.addChild( test, GUI_ALIGN_OVERLAP );
        m_externalWindow.setHidden(true);
    else if( mode == WindowMode_Undocked )
        gui.removeChild( m_content );
        m_externalGui.addChild( m_content );
        gui.removeChild( test);
        m_externalGui.addChild( test);
        m_externalWindow.setHidden(false);
    m_popoutSprite.SetHidden( mode == WindowMode_Undocked );
    m_windowMode = mode;
void Update()
    if( m_windowMode == WindowMode_Docked )
        // External window is open -> make sure we are in the correct window dock state
        if( m_externalWindow.WasOpened() )
            SetWindowDockMode( WindowMode_Undocked );
        m_content.setHidden( LoadingScreen::IsVisible() ? true : !m_isVisible );
        test.setHidden( LoadingScreen::IsVisible() ? true : !m_isVisible );
    else
        m_content.arrange();
        m_externalWindow.ResizeFor( m_content );
        // Did the user click close?
        if( m_externalWindow.WasClosed() )
            SetWindowDockMode( WindowMode_Docked );
Now the issue is, I can see my test button in the separate window but not the "content". What could be the issue here?
Note: The same logic use to work with Unigine 1
I will try to do that. It will take some time.
But, Do you see anything missed in above snippet? Is there something changed with respect to InterfaceWindow in Unigine 2 (may be some refresh call) ?
Priyank,
There was several bug fixes for the Interface plugin / widgets long time ago. It's hard to say what exactly causing such issue without a debugging - that's why we need a small test scene.
Btw, you are using 2.3.1 SDK?
Yes we are using 2.3.1
The issue was with the the setPosition call. Now we need explicitly set it every time before the arrange() call.
