a.bastani Posted February 7, 2017 Share Posted February 7, 2017 Hi guys, is there a possibility to start the animation of a WorldTransformPath via the Tracker? thanks Link to comment
alexander Posted February 8, 2017 Share Posted February 8, 2017 Hi Amin, Out of the box it's not possible. You can modify data/core/systems/tracker/parameters/node.parameters and add following lines at the end of the file (before the </parameters> tag): <!-- WorldTransformPath parameters --> <parameter type="node.world.transformpath.play" track="toggle" object="WorldTransformPath"> <set>if(VALUE) OBJECT.play(); else OBJECT.stop();</set> <get>VALUE = OBJECT.isPlaying();</get> </parameter> You also can copy attached file to your data/core/systems/tracker/parameters folder (tested in 2.3.1 / 2.4 and worked just fine). The new parameter added to the node -> world -> transformpath branch. node.parameters Link to comment
favre.nicolas Posted November 26, 2020 Share Posted November 26, 2020 Hi, how do you add the file node.parameters to data/core/systems/tracker/parameters folder ? It looks like the folder Core is lock I can't add file to it, I also tried to paste your file via the windows explorer but I don't find the Core folder in my project location. Regards, Link to comment
silent Posted November 26, 2020 Share Posted November 26, 2020 Hi Nicolas, You don't need to add WorldTransformPath into the Tracker parameters (it's already available in the latest releases - 2.12.x / 2.13.x). How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
favre.nicolas Posted November 26, 2020 Share Posted November 26, 2020 Ty for your answer, How do you set key value for this parameter ? I watched the tutorial of the animated material ball but it looks like it's different with world transformpath. I can't edit key, I can just create key but I don't have option to set the value as you can see in my screenshots, I would like to be able to animate the "time value". at frame 0 the time value is 0 and at frame 100 the time value of my world transform path would be at 100, that way when I move the slider of current time in tracker I would be able to see my animation. I would like to do it as well for an animated mesh ( Because I managed to link a camera to it thanks to this post ) Ty Link to comment
silent Posted November 26, 2020 Share Posted November 26, 2020 play is a toggle parameter, so you need to double click on a key at the timeline to enable it. After that you will see the green line indicating that parameter is toggled on: Duration between start and end should match the duration of transform animation in order to play without spikes. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
favre.nicolas Posted November 26, 2020 Share Posted November 26, 2020 Ok but I assume this won't allow me to play for exemple the animation backward or speed it, make a custome start, edit curves etc ? It's only "play the animation" or "pause it" and "play the animation where it was previously stoped" right ? Also can I have this option for a mesh bone based animation ? Link to comment
silent Posted November 26, 2020 Share Posted November 26, 2020 Yeah, Quote I assume this won't allow me to play for exemple the animation backward or speed it, make a custome start, edit curves etc ? It's only "play the animation" or "pause it" and "play the animation where it was previously stoped" right ? You can't control the speed or other parameters of these objects via Tracker. If you have a programmer nearby to help with the project you can achieve all of that via simple scripts and control objects via API. Quote Also can I have this option for a mesh bone based animation ? You can take a look into this post if you want to get more control for bone-based animations: Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
