rahul.ranjan Posted January 30, 2017 Share Posted January 30, 2017 I am loading the world through unigine as following, char cWorldPath[] = "world_load XYZ/XYZ"; Unigine::Engine *engine = Unigine::Engine::get(); Unigine::Console * console = Unigine::Console::get(); console->setActivity(1); console->run(cWorldPath); console->flush(); console->setActivity(0); int iNumPlugin = engine->findPlugin("MyPlugin"); MyPlugin *pPlugin = (MyPlugin*) engine->getPluginData(iNumPlugin); pPlugin->isWorldLoad(); // this function checks world is loaded or not and if loaded it loads tracks. everything is fine so far, but when I load the second world through the same process and try to call the plugin functions for rendering I get an Assertion as follows, --------------------------- Microsoft Visual C++ Runtime Library --------------------------- Assertion failed! Program: ... File: U:\source\engine\EngineInterpreter.h Line: 86 Expression: depth < NUM_INSTANCES && "EngineInterpreterInstance::begin(): stack overflow" For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts (Press Retry to debug the application - JIT must be enabled) --------------------------- Abort Retry Ignore --------------------------- I tried debugging throught the code and figured out that the problem seems to be in, void Machine::run(int begin,Interpreter::Context *context) which throws an access violation First-chance exception at 0x000007fed3f91e56 (.dll) in XYZ .exe: 0xC0000005: Access violation reading location 0x0000000000000208. on evey call to it, the trace to which is as follows, TRACE: Machine::run(int begin, Interpreter::Context * context) Line 57 C++ Interpreter::runFunction(int function, int num_args, const Variable * args) Line 6545 C++ Interpreter::runFunction(const char * name, int num_args, const Variable * args) Line 6475 C++ Interpreter::runFunction(const Variable & name, int num_args, const Variable * args) Line 6470 C++ Unigine::run_system_function(const Unigine::Variable & name) Line 1144 + 0x19 bytes C++ MyPlugin.dll!MyPlugin::cut() Line 41 + 0x40 bytes C++ MyPlugin.dll!MyPlugin::setIndex(SWITCHER_LAYER _layer) Line 78 C++ the execution is lost from the SWITCH case not sure where exactly but mostly in the CASE(CALLECFR). So what am I missing here, is there any closing steps needed to be undertaken before loading a new world or any reinitialization required before calling plugin functions? Link to comment
silent Posted January 30, 2017 Share Posted January 30, 2017 Hi Rahul, Could you please provide a small test sample (with plugin C++ code as well) so we can check it? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
rahul.ranjan Posted February 7, 2017 Author Share Posted February 7, 2017 Hi Andrey,Thanks for reply,I will provide you an exact scenario of our application and same plugin code.codes in the first thread is //These code are continously executed Unigine::Engine *engine = Unigine::Engine::get(); int iNumPlugin = engine->findPlugin("MyPlugin"); MyPlugin *pPlugin = (MyPlugin*) engine->getPluginData(iNumPlugin); while(1) { pPlugin->cut(); } In other thread //Executed for loading world char cWorldPath[] = "world_load XYZ/XYZ"; Unigine::Engine *engine = Unigine::Engine::get(); Unigine::Console * console = Unigine::Console::get(); console->setActivity(1); console->run(cWorldPath); console->flush(); Plugin void MyPlugin::cut() { Unigine::Engine *engine = Unigine::Engine::get(); engine->runSystemFunction("cut"); } int MyPlugin::init() { MyPlugin m_MyPluginObj; Unigine::Interpreter::addExternLibrary("m_MyPluginObj"); Unigine::Interpreter::addExternFunction("m_MyPluginObj.cut",MakeExternObjectFunction(m_MyPluginObj,&MyPlugin::cut)); return 1; } System Script using Unigine::Tracker; Unigine::Tracker::TrackerTrack track; Tracker tracker = new Tracker(); void cut() { track = tracker.loadTrack(trackPath[selection]); //different tracks are being loaded track.set(1.0f); } It works fine until the first time the world is loaded while loading the second time it crashes.if I comment the code:- track.set(1.0f); in script side then the application do not crash but I need to set time for track. Thanks. Link to comment
rahul.ranjan Posted February 15, 2017 Author Share Posted February 15, 2017 hi Finally, it's resolved, as it needs to delete track variable each time world gets unload in world shutdown and should be recreated each time a new world is loaded to avoid memory leakage. 1 Link to comment
