[SOLVED] Viewport::renderImage2D problem
Hello!
I want to view Splash image during the pause of exercise in my simulation. I read that it is impossible to do this with Unigine::Splash Class. So I tried to implement that idea using Viewport::renderImage2D() function.
Example of test code:
int AppWorldLogic::update()
ImagePtr pSplashImage = Image::create("defaultSplash");
pSplashImage->load("/home/userauto/workspace/TwrSim_Settings/defaultSplash.jpg");
ViewportPtr pSplashViewPort = Viewport::create();
pSplashViewPort->renderImage2D(Game::get()->getPlayer()->getCamera(), pSplashImage);
Render::get()->setViewport(pSplashViewPort);
I think that line of code is working
Because I see blinks at my screen and fps is going to become very low( 15-20 ). And I see my default viewport that i have set up using SDK browser anyway.
Also in log file i have that warning:
ImageFile::load(): unknown format of "defaultSplash" file. But it is okay with it. It has .jpg format.
What am I doing wrong?
Hi Grigorij,
Viewport::renderImage2D is not designed to render the desired image on top of the scene. You can check three main usages of Viewport class in documentation: https://developer.unigine.com/en/docs/2.3.1/api/library/rendering/class.viewport
In your case It's better to render fullscreen WIdgetSprite with desired texture instead of using complicated logic with Splashes.
  • silent changed the title to [SOLVED] Viewport::renderImage2D problem
