demostenes Posted November 5, 2016 Share Posted November 5, 2016 I ve tried to export terrain masks, used .psd as target, editor crashed. Link to comment
sebastianbah Posted November 7, 2016 Share Posted November 7, 2016 Hi, I'm afraid, we can't reproduce such behavior, so could you, please, do the following: 1. Check such behavior on terrain from samples 2. If samples works correctly send us the following: - Unigine log file of the crash in project - callstack, if possible - terrain from your project, if possible 3. If samples also provide crash, the following information would be helpful: - Unigine log file of the crash in project - additional information about your hardware from dxdiag - callstack, if possible Link to comment
demostenes Posted November 7, 2016 Author Share Posted November 7, 2016 Hi, can be simulated in scene provided here: https://developer.unigine.com/forum/topic/4003-terrain-mask-paint-crash/ Link to comment
tmorris Posted November 7, 2016 Share Posted November 7, 2016 We are also experiencing weird terrain export behavior in both versions 2.2.1 and 2.3.1. I have attached a word document with a bunch of data on the file formats and sizes we are using and where the problems start to arise. To summarize: New world from unigine browser with all defaults paths. -Created a new 1x1 terrain with a size of 8192 and all default paths. -Refined size = 8192x8182, course size = 2048 and detail texture arrays size = 2048 with 6 masks/materials. -Terrain parameters visible in node window do not match up with created assets at this point or parameters set in landscape plugin (seems to be visual bug only). -Can export all terrain data correctly when refined sizes in terrain parameters are set to 128, 256 & 512. -HOWEVER the editor crashes every time when trying to view a folder that contains the Masks exported at 512 but the image itself seems fine when viewed in a different program. -Can only export Height and Holes when the refined size is set to 1024+, albedo, normal and masks all cause hard crashes when trying to export at this size. Is there a reason only a subset of terrain export resolutions are working? Our artists would really appreciate this restriction being removed or an some clarification on intended workflow. I can recreate this behavior in any of our current worlds and on any new worlds we try and create. Landscape Import and Export notes for Unigine 2.3.1.rar Link to comment
sebastianbah Posted November 9, 2016 Share Posted November 9, 2016 Hi all,demostenes, I'm afraid we still can't reproduce your problem on the project you've sent.My reproduction steps:- get and unpack unigine_project.7z- add it to Unigine SDK Browser- run Editor, using "Edit Content" (directx11/opengl)- fly across the terrain to load terrain textures (~ 942Mb in profiler)- select Terrain_new_2 in Nodes- click Nodes -> Export tab -> Mask: Export- select Type: *.psd and write Name. Save the texture into data/ folder of the projectThis way I've got 2k x 2k x 20 R8 texture. No crashes appear.What should I change in reproduction steps to get the crash?Please, check these steps with the project you've sent. If crash appears, dxgiag information may help to get to the root of the problem faster.If the crash does not appear on a minimal test scene, I'm afraid, we need to check your full project.tmorris, Thanks for the report and such detailed instructions. It's a problem with creating preview of 16k texture and problem in 32k texture creation, but I'm afraid it's an expected behavior.If it's suitable for you, using Landscape plugin you may create several terrains (Increase Size X and Size Y values on Common tab of Landscape plugin) instead of the big one, so as a result, you can get several exported textures with the same level of detail, but the resolution of each texture will be lower.More detailed information about Landscape plugin in docs here. Link to comment
demostenes Posted November 9, 2016 Author Share Posted November 9, 2016 My reproduction steps: - get and unpack unigine_project.7z - add it to Unigine SDK Browser - run Editor, using "Edit Content" (directx11/opengl) - fly across the terrain to load terrain textures (~ 942Mb in profiler) - select Terrain_new_2 in Nodes - click Nodes -> Export tab -> Mask: Export - select Type: *.psd and write Name. Save the texture into data/ folder of the project This way I've got 2k x 2k x 20 R8 texture. No crashes appear. What should I change in reproduction steps to get the crash? Please, check these steps with the project you've sent. If crash appears, dxgiag information may help to get to the root of the problem faster. My step were exactly the same, I ve used this minimalistic project in clean sdk, data/ folder for export, etc...i will try to find some crash information. Thanks for your help. Link to comment
demostenes Posted November 11, 2016 Author Share Posted November 11, 2016 I ve found this in debug log: Assertion failed: (unsigned int)layer < (unsigned int)num_layers && "Image::getPixels2DArray(): bad layer number", file engine\framework\Image.cpp, line 6072 Dxdiag in attachement. DxDiag.txt Link to comment
sebastianbah Posted November 14, 2016 Share Posted November 14, 2016 Hi, As for error message, it may be caused by wrong array size/format or wrong format of the mask texture. So, please, could you try to check the following: - correct size and format of array textures - refined and coarse mask textures are correct: 3D textures, number of layers is equal to number of materials - there are no textures with the same as current terrain's mask/array texture names in data/ folder and in additional data_path folders Thanks for the information, we're still investigating the issue. Link to comment
demostenes Posted November 14, 2016 Author Share Posted November 14, 2016 Hi, As for error message, it may be caused by wrong array size/format or wrong format of the mask texture. So, please, could you try to check the following: - correct size and format of array textures - refined and coarse mask textures are correct: 3D textures, number of layers is equal to number of materials - there are no textures with the same as current terrain's mask/array texture names in data/ folder and in additional data_path folders Thanks for the information, we're still investigating the issue. Thanks for help, I have this log from scene I ve sent you. There shouldnt be any issues you mentioned. Link to comment
sebastianbah Posted November 15, 2016 Share Posted November 15, 2016 Hi, Thanks for your detailed information. We've reproduced the crash and added it to our internal bug tracker. In our test farm the crash appears on Nvidia GTX 400 Graphics series only, so you may try to upgrade your graphic card as a workaround, if it's suitable. Sorry for the inconvenience caused. Link to comment
demostenes Posted November 15, 2016 Author Share Posted November 15, 2016 Hi, Thanks for your detailed information. We've reproduced the crash and added it to our internal bug tracker. In our test farm the crash appears on Nvidia GTX 400 Graphics series only, so you may try to upgrade your graphic card as a workaround, if it's suitable. Sorry for the inconvenience caused. Yes, thats it, I have gf470. Reason why I am using it is simple, it is slow, so it forces me to optimize :) But good to know, that it should be ok anywhere else. Thanks for your help. Link to comment
radek Posted November 26, 2016 Share Posted November 26, 2016 In our test farm the crash appears on Nvidia GTX 400 Graphics series only, so you may try to upgrade your graphic card as a workaround, if it's suitable. Hi, I've the same problem on GTX 1080. It's been tested yesterday. Same version of Unigine that @demostenes has. R. Link to comment
sebastianbah Posted November 28, 2016 Share Posted November 28, 2016 Hi radek, I'm afraid we can't reproduce this problem on our GTX 1070 card. This issue is still active in our internal bug tracker, so we'll inform you in case of any changes. Thanks! Link to comment
demostenes Posted December 14, 2016 Author Share Posted December 14, 2016 We have replicated problem also on GTX 1070 with latest drivers. Link to comment
sebastianbah Posted April 20, 2017 Share Posted April 20, 2017 Hi, I'm afraid, we still can't get a stable reproduction for these crashes on your scene. If it possible to get the other scene, where the crash appears, it would be helpful. Currently, we can't give any ETA for the fix. Sorry for the inconvenience caused. Link to comment
demostenes Posted May 3, 2017 Author Share Posted May 3, 2017 Ok, so again. I ve exported our terrain into clean unigine 2.4.1 project. Flew over terrain to load all masks, selected export, psd type, put name and crash... debug: Assertion failed: (unsigned int)layer < (unsigned int)num_layers && "Image::getPixels2DArray(): bad layer number", file engine\framework\Image.cpp, line 7266 I ve uploaded whole project to your ftp as unigine_project.7z Link to comment
demostenes Posted May 20, 2017 Author Share Posted May 20, 2017 Crashing also on 1080Ti Link to comment
silent Posted May 22, 2017 Share Posted May 22, 2017 Hi Jirka, Thank you for the updated test scene! This crash is not related to GPU (as we can understand from the callstack). With your new terrain indeed we can reproduce this behavior easily. I will try to raise priority for the old terrain bug, but can't guarantee that it will be fixed in 2.5 or 2.6 SDK update, sorry. Thank you for the updated test scene! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted May 23, 2017 Share Posted May 23, 2017 Crash fixed. Fix will be available in the next SDK update. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
demostenes Posted May 23, 2017 Author Share Posted May 23, 2017 Crash fixed. Fix will be available in the next SDK update. Thanks! Link to comment
