joseph.howell Posted August 29, 2016 Share Posted August 29, 2016 Hi, On Friday I updated to the 1.7.4 Browser and the 2.3 SDK. Launching demos and projects from the browser no longer works. I can build projects in Visual Studio and run them from there, but from the browser is a no go. It simply brings up a black window for less than 1 second and then disappears. I can see there is some sort of error text in the black window, but it disappears so quickly that I can't see what it is. I thought I'd see what the text was by launching from command line, but it works there as well. The only place it doesn't work from is the browser. Thanks Link to comment
silent Posted August 30, 2016 Share Posted August 30, 2016 Hi Joseph, If your projects are C++ / C# based - you need to manually rebuild all configurations from the Visual Studio (basically, it's Release and Debug). If you created x86/x64 application - you need to rebuild also x86/x64 configurations. By default browser is trying to run release executable (you can enable debug executable launch in option ([...] button). This happens because of the upgrade procedure: it doesn't invoke visual studio compiler to rebuild your applications (that I assume was built for 2.2.1 version) and they are simply not compatible with new Unigine library from 2.3. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
joseph.howell Posted August 30, 2016 Author Share Posted August 30, 2016 launching_bug.mp4 Well, no. What I mean is that I built a brand new 2.3 project and it won't run. I CAN run that new 2.3 project from either Visual Studio or from the command line, but the browser won't launch it. Also, NONE of the demos or sample apps that shipped with 2.3 will run from my browser. Here's a video I made of the problem so you can see it in action. Or I also attached it if you'd rather see it that way. Link to comment
joseph.howell Posted August 30, 2016 Author Share Posted August 30, 2016 Since recording the video, I was able to pause and finally read the error message. "'MySQL' is not recognized as an internal or external command, operable program or batch file." And in case you're wondering, I do have MySQL on my PATH already. But does unigine use MySQL? Is this a new requirement? MySQL folders in my path: C:\Program Files (x86)\MySQL\MySQL Fabric 1.5 & MySQL Utilities 1.5\ C:\Program Files (x86)\MySQL\MySQL Fabric 1.5 & MySQL Utilities 1.5\Doctrine extensions for PHP\ C:\Program Files\MySQL\MySQL Server 5.6\bin C:\Program Files\Microsoft SQL Server\110\Tools\Binn\ C:\Program Files\Microsoft SQL Server\120\Tools\Bin\ Link to comment
paralyzah Posted August 31, 2016 Share Posted August 31, 2016 Hi JosephThe root of problem is symbol "&" in your PATH environment variableI just add to my PATH string: C:/m & m; (with reboot OS) and i get next error message: ''m' is not recognized as an internal or external command, operable program or batch file."It's a bug and it will be fixed in next release of sdk browserYou can use next solutions:1. Reinstall MySQL Fabric 1.5 & MySQL Utilities 1.5 software to another folder (without "&" symbol in the path). I checked software MySQL Fabric 1.5.6 and by default it was installed to folder without any "&" symbols2. Also, you can manually add ^ symbol before each & symbol in the PATH variable (with reboot OS of course). More info you can find here: https://en.wikipedia.org/wiki/Batch_file#Escaped_characters_in_strings your PATH will be next, for example:C:\Program Files (x86)\MySQL\MySQL Fabric 1.5 ^& MySQL Utilities 1.5\C:\Program Files (x86)\MySQL\MySQL Fabric 1.5 ^& MySQL Utilities 1.5\Doctrine extensions for PHP\But please remember, it's a not so good solution and correct work of MySQL Fabric does not garanteed (but sdk browser will works correctly)btw you can see your actual PATH with next steps:run cmd.exetype echo %PATH% and press enter Sorry for the inconvenience caused. Link to comment
joseph.howell Posted August 31, 2016 Author Share Posted August 31, 2016 Putting in the ^& leads to a new problem. The apps now launch but freeze and then changes such as mouse movement get captured on the screen. It's hard to describe, so I'll put in a new video. Link to comment
silent Posted August 31, 2016 Share Posted August 31, 2016 Hi Joseph, Could you please check the Options at the top of SDK Browser to see if HTC Vive output is enabled? Please, also post an engine log.html file from <Project>/bin directory - it should contain useful information about the errors. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
joseph.howell Posted August 31, 2016 Author Share Posted August 31, 2016 Ah yes, that was it. I still had the HTC Vive activated from when I was working on the vive. Thanks. Link to comment
silent Posted August 31, 2016 Share Posted August 31, 2016 Hi Joseph, You can always open console (~ key) and check the engine log to get the current status of the running application (check if there are any errors os warnings). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
