zhang.jian_bin Posted August 17, 2016 Share Posted August 17, 2016 i'm developing in the exe mode, not the plugin mode. The version is 2.3, and i had done as follows: 1 create Mesh 2 add the Mesh with 1 a sphere surface 2 a cube surface (set vertices and indices one by one) 3 construct ObjectMeshStatic from the Mesh 4 set setMaterial, setProperty,for the ObjectMeshStatic 5 save the node by using World::get()->saveNode("F:/mydemos/myTest1/data/Yaya.node") it is all right currently, but the node file has no geometric info. if i did so in the editor, the geometric info would appeared in the XML tag <vertex> and <indices> here is my node file: <?xml version="1.0" encoding="utf-8"?> <nodes version="2.3"> <node type="ObjectMeshStatic" id="1584404555" name="someName"> <mesh_name/> <surface name="someSurfaceName" material="mesh_base" property="surface_base"/> <transform>1 0 0 0.0 0 1 0 0.0 0 0 1 0.0 0 0 9.99999974738e-005 1.0</transform> </node> </nodes> How can i export a reference node like the editor do? Link to comment
zhang.jian_bin Posted August 17, 2016 Author Share Posted August 17, 2016 I looked into the "node_export.cpp" script used by the editor, it seems export a reference node needs a lot of work, is there a simple way? Link to comment
silent Posted August 17, 2016 Share Posted August 17, 2016 Hi Zhang, In case of NodeReference, there is no easier way, I'm afraid. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
zhang.jian_bin Posted August 17, 2016 Author Share Posted August 17, 2016 Well, i have to transfer the Unigine Script code into C++ code. Or, can i call Unigine Script functions in C++? Link to comment
silent Posted August 17, 2016 Share Posted August 17, 2016 For almost each UnigineScript function there are analogue in C++ / C# API. You will have to deal with ownership first (in C++). However, you can also call UnigineScript functions via Callbacks: https://developer.unigine.com/en/docs/2.3/code/cpp/usage/callbacks Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
zhang.jian_bin Posted August 18, 2016 Author Share Posted August 18, 2016 well, good. i will try the callbacks Link to comment
