marinos.giannoukakis Posted July 27, 2016 Share Posted July 27, 2016 can you please indicate with a photo or something where the Syncker slave demo button is? cause i can t seem to find it..... "You can try out Syncker samples in Unigine SDK that run Syncker directly from world scripts. On each slave computer, open Unigine SDK Browser and press the Syncker slave demo button, which is located on the Samples & Demos tab under the High-Level Systems section."Thank you.... Link to comment
silent Posted July 28, 2016 Share Posted July 28, 2016 Hi Marions, We are deeply sorry, but the new SDK Browser is not capable of running Syncker slaves. You can use following .bat file (assuming that you are using windows): @echo off setlocal EnableDelayedExpansion if %processor_architecture% == AMD64 ( set arch=x64 if not exist bin\main_x64.exe ( set arch=x86 ) else ( set PATH=!PATH!;%~dp0lib\x64 ) ) else ( set arch=x86 ) set PATH=%PATH%;%~dp0lib; start bin\main_%arch%.exe -data_path ../ -editor_script core/systems/syncker/syncker_slave.cpp -slave_name "test" -console_command "editor_reload" Just create *.bat file and copy it into <SDK> root directory (for example, D:\SDK_Browser\sdks\sim_windows_2.2.1-2_src). Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
binstream Posted July 28, 2016 Share Posted July 28, 2016 It is planned to rework Syncker implementation (together with deployment tools) in 2.4 release to simplify its use. Link to comment
marinos.giannoukakis Posted July 31, 2016 Author Share Posted July 31, 2016 thank you both....:D Link to comment
