Question about node rotation
Hi everyone,
    There are a question about rotate a node,  There is the default material in the new C++ project's scene:
     After rotate the material_ball  about Y-axis by these code:
        node = Editor::get()->getNodeByName("material_ball");
	Mat4 transform = node.get()->getTransform();
	mat4 rot = rotateY(90.0f);
	node.get()->setTransform(transform * Mat4(rot));
    The material_ball become this:
     And then I rotate it about Z-axis by these code:
	mat4 rot2 = rotateZ(-30.0f);
	node.get()->setTransform(transform * Mat4(rot) * Mat4(rot2));
Form the above view, I find that the rotate function is rote the node about it's own axis, How can I rotate it about the world axis ? I have tried the setWorldTransform function like this:
	Mat4 transform = node.get()->getWorldTransform();
	node.get()->setWorldTransform(transform * Mat4(rot) * Mat4(rot2));
But it's result is the same with setTransform function.
I think you multiply matrices in the wrong order.
Here's what happening in your last snippet: the node is rotated by -30 degrees along Z axis, then by 90 degrees along Y axis and then the original transformation is applied.
By the way, Ptr<T> has overloaded operator->, so you can invoke methods without ".get()".
Please try the following code:
mat4 rot_y = rotateY(90.0f);
mat4 rot_z = rotateY(-30.0f);
node->setWorldTransform(transform * Mat4(rot_z) * Mat4(rot_y));
