ataylor Posted June 20, 2016 Share Posted June 20, 2016 I am trying to use a Blob to compress an existing file on disk: Unigine::FilePtr fileIn = Unigine::File::create("someFile", "rb"); Unigine::FilePtr fileOut = Unigine::File::create("someOtherFile", "wb"); Unigine::BlobPtr blob=Unigine::Blob::create(fileIn->getStream()); blob->compress(fileOut->getStream(), 1); But engine crashes inside Blob::compress function. I see that there is another Blob constructor -- Blob::create(size_t size=0). If I use this function to create the Blob, there is no crash. fileOut is written successfully but of course has almost no content as the blob is empty. I assume I would need to manually read in the bytes of fileIn and write them to blob. This is OK, but if there is a way to have this done automatically I would prefer that. Documentation for Blob class only shows a single create() function, and it seems wrong: Ptr<Blob> create (const Ptr<Stream> & stream)Blob constructor. Arguments const Ptr<Stream> & stream - Size of the blob in bytes. Is there a working example of initializing a Blob from a Stream? Link to comment
ded Posted June 21, 2016 Share Posted June 21, 2016 Hi, I'm afraid there is flaw in the API. Ptr<Blob> create (const Ptr<Stream> & stream); Really should be declared as: Ptr<Blob> create (const Ptr<Blob> & stream) It's a copy constructor for a Blob. Blob has no functionality to read all data from the another stream. You'll have to read the file contents yourself, for example like this: while (!fileIn->eof()) fileIn->readStream(blob->getStream(), BUF_SIZE); We'll fix the constructor signature, thank you for noticing the issue and sorry for the inconvenience caused. Link to comment
ataylor Posted June 21, 2016 Author Share Posted June 21, 2016 Okay, thanks, can mark as solved. Link to comment
