philipp.almer Posted June 3, 2016 Share Posted June 3, 2016 Hi all I have an issue with creating lakes in Unigine. Depending on the view angle, the water act quite wierd. When I look at the water from above, the water itsself is not visible at all and I can't find anything to tune this accordingly. What is the correct approach to make a lake? Link to comment
silent Posted June 3, 2016 Share Posted June 3, 2016 Hi Philipp, Could you please share with us your water material parameters (from all tabs in Material window)?Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
philipp.almer Posted June 6, 2016 Author Share Posted June 6, 2016 Hi Andrey Please create a new project with the name "Phil_Playground" and copy the attached files into it. You will find a custom made lake which reacts correctly. And another one which has bizarre boundaries and disappears while flying over it. Thanks, Phil & Renato Phil_Playground.zip Link to comment
demostenes Posted June 6, 2016 Share Posted June 6, 2016 I ve noticed, that since upgrade to 2.2 lakes are behaving in totally different way. Our settings are useless, it must be tweaked again. But so far I had no time to play with it. Some sample would be handy. Link to comment
philipp.almer Posted June 6, 2016 Author Share Posted June 6, 2016 When I switch on the planar reflections for the water material only half of the lake reflects. And as soon as I move the camera to the reflecting side of the lake, the reflections are gone everywhere. Objects which should reflect on the water (ridgeline of the island) are not reflected at all. Reflection mask set to 1 and surface viewport mask of the reflecting object set to 1. Am I missing something? Link to comment
philipp.almer Posted June 6, 2016 Author Share Posted June 6, 2016 Reflection problem solved.... Forward/Up coordinates were wrong during FBX export. Link to comment
grmmvv Posted June 7, 2016 Share Posted June 7, 2016 Hi, We can't reproduce your issue on our content, sorry. Unfortunately, scene you sent us contains external links onto the meshes, so we cant open world properly, ex: "../../../Blender/ELITE/Water_Test/meshes/Landscape.mesh" Please copy all necessary meshes into <Project_dir>/meshes and reattach project again. Thanks! Link to comment
philipp.almer Posted June 7, 2016 Author Share Posted June 7, 2016 Hi Sorry for the inconvenience. Phil Phil_Playground.zip Link to comment
grmmvv Posted June 7, 2016 Share Posted June 7, 2016 Unfortunately, project still contains two external link onto the meshes. There is: "../../../Blender/ELITE/Water_Test/meshes/Plane.mesh" used in "new_lake_pivot_centered" ; "../../OneTileWashington/data/washington/meshes/washington_lakes_x00_y05.mesh" - used in "lake_geo_referenced" Please, send us these meshes too. Thanks! Link to comment
philipp.almer Posted June 7, 2016 Author Share Posted June 7, 2016 My apologies, now it should be all. :unsure: Phil_Playground.zip Link to comment
grmmvv Posted June 7, 2016 Share Posted June 7, 2016 Thank you for the test scene. I've successfully reproduced the issue and added ticket to our internal bug tracker. There is a problem with pivot offset and Water Mesh. As a workaround, you can center pivot to source mesh and use this mesh as reference in WaterMesh. Link to comment
philipp.almer Posted June 7, 2016 Author Share Posted June 7, 2016 Many thanks for your answer, grmmvv. I don't understand your workaround yet, but I try to sort it out. I will ask again if i can't Phil Link to comment
philipp.almer Posted June 7, 2016 Author Share Posted June 7, 2016 Hi all I have another question regarding the WaterMeshObject. According the Docs, a WaterMeshObject "consist of 2 surfaces approximating optical and dynamic behavior of water": - surface - volume When I create a WaterMeshObject there is no volume surface at all. How is this volume surface created? Link to comment
grmmvv Posted June 8, 2016 Share Posted June 8, 2016 Many thanks for your answer, grmmvv. I don't understand your workaround yet, but I try to sort it out. I will ask again if i can't Phil When you create reference for Water Mesh in any 3D Editor, you need to set pivot of an object at the geometric center of your object. Hi all I have another question regarding the WaterMeshObject. According the Docs, a WaterMeshObject "consist of 2 surfaces approximating optical and dynamic behavior of water": - surface - volume When I create a WaterMeshObject there is no volume surface at all. How is this volume surface created? Unfortunately, article about Water Mesh is a little bit outdated and will be fixed with the next SDK update. There is no way to create volume surface for WaterMesh. Sorry for the inconvenience caused. Link to comment
philipp.almer Posted June 8, 2016 Author Share Posted June 8, 2016 Got it. Thanks for clearify. Phil Link to comment
renato.semadeni Posted July 14, 2016 Share Posted July 14, 2016 Hi there Do you have a solution for the water masks as used in PortAngeles. Since the above workaround suits only single lakes. Kind regards, Renato Link to comment
silent Posted July 14, 2016 Share Posted July 14, 2016 Hi Renato, Could you please elaborate - what do you want to achieve?Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
renato.semadeni Posted July 14, 2016 Share Posted July 14, 2016 Hi Silent We have a lake mask for all tiles in our landscape. With the 2.2.1-2 we observe the above described problem, that the water is not shown from above. With the mentioned work around is was possible to get rid of this phenomen in our testbed. Thank you for the test scene. I've successfully reproduced the issue and added ticket to our internal bug tracker. There is a problem with pivot offset and Water Mesh. As a workaround, you can center pivot to source mesh and use this mesh as reference in WaterMesh. The work around was to center the pivot to the source mesh, but since we a mask which generates multiple meshes distributed in the tile, we can't center the pivot to the source mesh anymore. Kind regards, Renato Link to comment
silent Posted July 14, 2016 Share Posted July 14, 2016 Hi Renato, I've raised priority for this ticket. In 2.3 SDK release we will try to get rid of the visual artifacts for ObjectWaterMesh with non-centered pivots. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
sebastianbah Posted July 22, 2016 Share Posted July 22, 2016 Hi all, Fix for this issue is already available in 2.3-beta2 SDK release. Please, check it and report us back if you still have any problem with lakes. Thanks! Link to comment
philipp.almer Posted July 22, 2016 Author Share Posted July 22, 2016 Problem is solved with 2.3-beta2. All lakes in our tiles now behave as expected. Thanks. Link to comment
