zheng.guan Posted April 29, 2016 Share Posted April 29, 2016 How could I convert a string type which I got from editlinewidget to an int type? THANKYOU! Link to comment
koshachy Posted April 29, 2016 Share Posted April 29, 2016 Hi Zheng Guan, If you use UnigineScript, you easily use this type conversion function: https://developer.unigine.com/en/docs/2.1.1/scripting/core/types#int_variable Please, take into account that parser will return only first non-whitespace characters. In the example below, the log.message function will return 344 /* ... */ Gui gui = engine.getGui(); WidgetEditLine line = new WidgetEditLine(gui, "344 343"); int i = int(line.getText()); log.message("%i\n",i); We've lost this article in 2.2.1 documentation and will add it ASAP.Thank you! Link to comment
zheng.guan Posted May 6, 2016 Author Share Posted May 6, 2016 oh thank you! and now i have another question why i got an error "object is null in class widgetEditLine * __ptr64 class" when i used the function “line.getText()” as your example? i defined a widgeteditline in .ui file and set a callback function like this <callback type="changed">Interface::get_day</callback> when i input numbers in the editline, the function run correctly but the error came out what should i do? Link to comment
koshachy Posted May 6, 2016 Share Posted May 6, 2016 Hi Zheng Guan,As I can see, you created your own class called Interface and try to call the callback from it.Well, in this case, you should create a callback redirector for calling callbacks. Look through the "samples/widgets/ui_02.ui" sample or just implement something similar: I've create ui_test.ui file: <?xml version="1.0" encoding="utf-8"?> <ui version="1.0"> <editline name="EditLine::editline" export="1" width="100" capacity="10"> <callback type="changed" instance="EditLine::instance" string="changed">EditLine::callback_redirector</callback> </editline> </ui> and added callback_redirector method inside my EditLine class: class EditLine { EditLine instance; WidgetEditLine editline; UserInterface ui; EditLine() { // we use this to know what's the instance is linked. // this helps if you create 2 WdigetEditLines in UI and want to control them by this class instance = this; ui = new UserInterface(engine.getGui(),"ui_test.ui"); } // add the editline widget to scene void show(int x,int y) { Gui gui = engine.getGui(); gui.addChild(editline,GUI_ALIGN_OVERLAP); editline.setPosition(x,y); } // callback to be called on changing editline void changed() { int i = int(editline.getText()); log.message("the line is %i\n", i); } // redirector. calls corresponding callback by using its name. void callback_redirector(string func,EditLine editline){ editline.call(func); } }; in the world script's init() method, I create an instance of EditLIne and call show() method: EditLine el = new EditLine(); el.show(200,200); Hope this helps! Thank you! Link to comment
